Question about Humax PVR9300T HD DVR
Picture and sound keep jumping on playing back a recording, most annoying as usually loose section of recording.
Posted by steve Slyfield on
Russ Hill
  • 4,057 Answers
Hard drive failing.
Posted on Oct 06, 2013
Recorded programmes from some channels break up- both the picture and sound- when replayed
I've got one. Does exactly the same thing. It usually happens within the first, say, 10 hours of recorded material. This is the most used part of the hard drive disc. We have 5-9 hours of programs we intend to keep so we end up re-recording over the next part of the disc repeatedly. This wears that part down. What I did was keep 2-3 hours of stuff in that zone and carried on recording and deleting as usual, as I still do. I'm watching it right now. But if I erase past the break 'zone', the recordings 'jump'. It has a big memory and shouldn't be a problem. So..........fill with programs to half the disc and record over the lesser used part of the disc.....it works for me. I'd be interested in hearing how you get on. Good luck Red.
Mar 04, 2015 | Humax PVR9300T HD DVR
My VIP622 keeps jumping back to live TV when I try to back up while watching live TV, or if I resume playing after pausing. But if I've recorded a whole program, I can play, pause, back up okay.
Hello, my name is Daniel Busa with Dish Network customer service, I reviewed your question I have seen this before, t sounds like its possibly a bad hard drive try unplugging your reciever for ten seconds if it's persisting then we may need to replace it.
Dec 10, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Sound and picture jumping
This is probably because this camera records in HD format which will jump around when played on computers that are not very high performance. You need at least 2gb of RAM and a decent processor.
Otherwise, the codec is missing or old for playing the format.
Nov 19, 2009 | Canon PowerShot SX 200 IS Digital Camera
When playing a DVD, gets sound but no picture,message ''no signal''
If you are using a Scart connection, ensure the scart is sitting fully home from the back of the TV & the rear of your DVD. Best thing is usually to pull it out & then push it back in. This is usually caused because the Scart has come loose.
Mar 28, 2009 | Televison & Video
I have a lg d v d recorder when i record home footage ie from camcorder tape to d v d - r records ok and play s back on main player ok after ...
Does it do this on the machine where it was originally made?
If so issue is with your dvd recorder. If not then there are compatibility issues with the other units. U might want to try using different media.
Aug 27, 2017 | Televison & Video
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Sound but no picture.
if you are able to playback previously recorded cassette and the picture is perfect then its not the head. then the problem is with the image grabbing section i.e. the CCD. May be its damaged and needs replacement.
Jan 19, 2008 | Video Cameras
Recording from my vcr to the dvd hardrive
It may be that the tape you are trying to record from is copy-protected. You will then get a "scrambled" picture
Nov 04, 2007 | Wharfedale DVD-M3 DVD Player
Picture and sound is skipping or stuttering during playback. It happens when playing any video.
This was often caused by mixing brands of tape. Do not use head cleaners more than absolutely necessary. More than half a dozen times or so, and heads are toast.
Use quality tapes of the same make/length, from new, and you will be fine. (the coatings on the tapes vary, and can/did interact with each other.)
Nov 02, 2007 | Sony Handycam DCR-TRV310 Digital Camcorder
Humax PVR9300T HD DVR Logo
149 people viewed this question
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
