Question about Tamron Cameras
Clicking sound in Autofocus: I have a Tamron
Clicking sound in Autofocus: I have a Tamron 18-270mm f/3.5-6.3 Di II VC PZD. When I use Autofocus I hear a terrible clicking sound periodically as it's searching. I really like this lens and I've only owned this lens for 2 months. So far I've done very little shooting on it and what I've shot has mostly been in manual mode. Is this clicking a sign of trouble and is it fixable?
Posted by James Meyer on
4 Related Answers
rajdeepdutta
RAJDEEP DUTTA
  • 2517 Answers
SOURCE: Sigma 28-105 aspherical IF lens: Daughter
Hi we was in the chat session. Please watch the image below & the problem is in red mark location. Thanks.
Posted on Feb 17, 2010
fikretunalir
FIKRET UNALIR
  • 239 Answers
SOURCE: Tamron lens makes a clicking noise
It is dealing with the films. when closing the lens in the fabric, the electrical film changed its position to an unwanted situation. This makes noise sometimes. It is not important for functinality of the lens. But it only gives you an unwanted noise. There is nothing to do because film dries as the times passes. It needs to be changed but is not cheap. So it is better to go on to use it.
Posted on May 28, 2010
akangpepen
Steven Pepen
  • 133 Answers
SOURCE: my Nikon 55-200mm will not function in autofocus
hi there,
i`ve once experienced the same problem as your,
the reason was the motor in the lens. it couldn`t work normally
to trouble shoot this, you should contact a professional service technician,
and i hope the lens is still in warranty condition
thanks
Posted on Jan 17, 2011
Testimonial: "Thanks. I really didnt want to hear that, but that was my guess too."
  • 102366 Answers
SOURCE: What is the focal length
It's not the lens but the camera that determines the focal length multiplier. On some cameras the 18-270mm lens is an 18-270mm. The XSi's imaging sensor applies a 1.6x multiplier on any lens used with the camera, so the 18-270mm will be approximately 29-430mm.
Posted on Mar 05, 2011
My tamron lens 18-270mm pzd is flickering and having difficulty in focusing. Where can I get it fixed.
Go to the tamron site and find the nearest repair centre to you location
Feb 27, 2016 | Tamron Cameras
As all tamron lenses i used. it stops working in the middle of shooting!!?
I know this is a shot in the dark, but have you cleaned the afore-mentioned contacts, both on the lens and the camera, using s clean dry lint-free cloth ?
Jan 27, 2016 | Tamron Af 18-270 3.5-6.3 Di Ii Vc Lens For...
What is the original settings for my camera
its pretty good Cannon EOS 50D w/Tamron AF 18-270mm F3.5-6.3 Di II VC Digital camera
Mar 13, 2012 | Cannon EOS 50D Digital Camera
Was I sold a 'pup'? Tamron lens box says AF55-200mmF4-5.6LD MACRO. Can't find macro setting on lens or instructions. Looking at your site, Product Details says 'No Macro'. So what's...
Excerpted from a www.photo.net review of the lens:
Though the Tamron AF 55-200mm Di II LD Macro has "Macro" in its name, it's not really a macro lens. Maximum magnification is about 1/3 life size (Tamron spec it at 1:3.5) as you can see from the following image below, which was shot at 200mm and at the closest focus distance (0.9m/37.4"). This isn't too bad, but it's more of a close focus telephoto lens than a "macro" lens (bolding for emphasis added).
Sep 09, 2011 | Tamron 55-200mm f/4-5.6 Di-II LD for Canon...
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
What is the focal length multiplier for the Tamron 18-270 mm Di-II PZD VC lens on a Canon XSi digital camera?
Mar 05, 2011 | Cameras
Tamron 28-200 AF Aspherical LD. Does it have manual focus? If yes, where?
There should be a switch just in front of the back of the lens marked "AF" and "M". Set it to M for manual focus, AF for autofocus.
Aug 30, 2008 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Cameras Logo
Top Tamron Cameras Experts
Steven Wander
Steven Wander
Harrie
Are you a Tamron Camera Expert? Answer questions, earn points and help others
