Question about Kyocera FS-3830N Laser Printer
Epson Aculaser C1100. Message says "MK toner low". I've replaced the Cyan cartridge, but the message remains and the printer will not print. Test page prints OK. What shouild I do?
Posted by Martin Esseen on
Tech Bravo
  • Kyocera Expert
  • 337 Answers
M is magenta toner, k is black. try replacing the m and k toners.
Posted on Nov 30, 2013
5 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
Posted on Feb 04, 2009
Anonymous
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
acdr
kishor khatri
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
Copier_God
Brian
  • 57 Answers
SOURCE: message stating install MK
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Posted on Oct 16, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
The black toner needs replacing but I can't get to it. The Cyan toner is at the front and I can't move it round to get to the black! It's an Epson Aculaser C1100
there maybe a cartridge replacement button to drag the print head etc out of the way so you can get at the cartridges.
I hope this was helpful
Jan 11, 2011 | Epson Aculaser C1100 Printer
I have an error message saying "replace toner c" do you know what to do?
hi,
your cyan cartridge is empty, you should replace it by a new one.
Oct 20, 2010 | Epson Aculaser C1100 Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
What colour is K on low ink
Toner K low refers to the black toner.
May 15, 2009 | Epson Aculaser C1100 Printer
Cant change ink cartridge - says needs mk toner,
I struggled with this and it sent me nearly mad. Epson need their heads read for not giving the instructions either on the toner box or inside the printer. What customer care? I'm sure I'm not the only one who has felt like putting a sledge hammer through the ******* thing.
The other answer on this Fixya site says use the printer driver. That's not right for my computer. There is nothing on the driver about it.
To get the correct toner cartridge to face you when you open the front door... use the menu screen on the printer itself and the 4 buttons that are in a wheel shape. By default you are in the Information menu. Scroll down to Reset menu, using the bottom button. Press the right button (with the return arrow) to select this menu. The first visible option is 'Clear warning' which is a useful one to get rid of the endless warnings! But instead of selecting that, scroll down through this Reset menu until you come to 'Change Toner C', which is followed by M then K then Y.
In case you're wondering which is which - they are confusingly not in the same order as the colours on the printer. Cyan (blue), Magenta (red), K Black, Y Yellow.
Hope this saved the sledge hammer, and hope Epson one day think...
Nov 05, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Kyocera FS-3830N Laser Printer Logo
274 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
