Question about Pentax MZ-60 QD 35mm SLR Camera
Battery size - Pentax MZ-60 QD 35mm SLR Camera
Jim Jordan
    Master:
  • Pentax Master
  • 442 Answers
The MZ-60 takes a CR2 Lithium Photo Battery, available at most hardware stores, pharmacies and online at Amazon.com.
Posted on Dec 16, 2014
2answers
What size battery for a 1998 dodge dakota v6 pick up truck
Size 24 or 27. I found this on the AutoZone website. You can too.
1helpful
What size replacement battery do i need to but?
it depends up on the size of your vacuum cleaner.A range of 12v batteries are available and this battery is for only small size it varies with size to size.
Custom Car Body Kits
Jun 15, 2012 • Vacuums
I need the size of 3230 mobile Battery size with pictur?
Nokia 3230 mobile uses BL-5B battery.You donot require the size of the battery.Please tell the model number and they provide you the correct battery.
Aug 10, 2010 • Nokia 3230
1helpful
What size batteries do i need for 96 canter fe211
GO TO ANY AUTO PARTS PLACE TELL THEM YEAR MODEL TYPE OF CAR.WHAT ENGINE SIZE AND TYPE FUEL INJECTION SYSTEM.THEY WILL LOOK UP WHAT BATTERY SIZE YOU NEED.
3helpful
2answers
Need battery size for 1996 Dodge Caravan
your cars battery might only need charging or battery acid replacement, but if you'd realy wish to buy new one, buy one with the same size and voltage and amps as the one you have right now, or you could buy a battery with the same voltage with a higher amppere-hour (Ah) rating!
3helpful
2answers
Need size of battery for 2000 ford focus
Dependant on engine size and fuel type, any size from a 390 amp battery, if it is diesel then a 590 amp battery. No special tools needed, only a small ring spanner. Make sure yyou disconnect the earth lead first. Also you will need to enter the radio code after changing batteries
What is size of replacement battery for 2000 sonata v6?
Size 75 was the standard battery many of the newer size 75's are actually stronger than the old 78's, so you can probably get away with a 75 which is a little smaller and lighter.
1helpful
Need to know the physical size of a battery for a 1996 Cherokee.
Your Jeep Grand Cherokee uses a group 34 type battery. The sizes vary from manufacturer to manufacturer but, the standard size is 10 1/4 " x 6 13/16" x 7 7/8" or 260mm x 173mm x 200mm. Anything close should fit fine. Good luck. Please ask for help any time. Please rate me so I know how I'm doing. Thanks
2003 3.2TL battery size
where ever you buy a new battery they will have the sizes to fit your car.
Batteries
The E-10/20N battery holders are designed to fit the longer type CRV-3 lithium batteries and conventional sized AA NiMH batteries. Once installed into the battery compartment the AA sized batteries will make an electrical contact with the camera
Pentax MZ-60 QD 35mm SLR Camera Logo
Top Pentax Photography Experts
Ekse
Are you a Pentax Photography Expert? Answer questions, earn points and help others
