Cell Phones Logo
A
Anonymous Posted on Oct 04, 2013
How to set speed dialing on at&t 2222 - AT&T Cell Phones
Do you have any volt,amp meters, that can tell where I can set the governor to? These dials are fixed to the generator. Hum...
No gauges can set the governor . The governor controls the engine at a set speed, as the load on the generator varies so does the engine speed ,the governor tries to keep the engine speed constant.
18helpful
3answers
How set speed dialing in samsung b7722
Go to contacts. on upper dropbox select favourites & that's it.
1helpful
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
I want to forward my work calls to my cell phone, but I do not know how Please help
Is this an IP Office? If so:
If so, at your phone, you need to set the number to forward to:
Press: *07*9xxxxxxxxxxx#
(where 9xxxxxxxxxxx, is the dial "9" access code to dial outand the number how you would dial it, followed by pound)
so for 555-111-2222...
*07*915551112222#
Once that is done, you need to turn forwarding on:
*01
To turn forwarding off:
*02
Upon entering the codes, you will get a double "blip" tone to confirm the acceptance of the code.
How would I set up on my fax machine to send one report to multiple numbers?
You need to add numbers first in all Speed Dial & then add those speed dials in Group dials.So that you can send that group to all locations at 1 time.
If you think it was helpfull rate me..
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
1helpful
Accidentally set the pulse/tone dialing feature to pulse for a Ricoh 4430L. How do I change it ?
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
4helpful
I would like to forward all calls to my cell phone
Which system do you have? IP Office?
*07*915551112222#
*01
*02
HI , I have the avaya phone, and i was wondering if it has call forwarding
IP Office?
*07*915551112222#
*01
*02
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
