NEC Dterm DTP 32D-1 Corded Phone Logo
Question about NEC Dterm DTP 32D-1 Corded Phone
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Posted by Roni Flaherty on
SC Spike
    New Friend:
  • 91 Answers
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Posted on Jul 12, 2014
5 Related Answers
Anonymous
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
Anonymous
SOURCE: NEC Dterm 80
http://www.battscom.net/User%20Guides/IPK/IPK%20Multiline%20Telephone%20UG_2b.pdf
Posted on Oct 10, 2008
Brian LaDuca
  • 149 Answers
SOURCE: time change
depends on the type of system.
feature 9# enter time.
feature to save
Posted on Nov 13, 2008
Anonymous
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
Anonymous
SOURCE: How do I make a conference call with the NEC Dterm
To establish a 3 way conversation.
  • Pick up handset and dial first number required
  • While on the call, press Transfer (TRF) button
  • Caller will be placed on hold
  • Dial extension number or external number
  • When called answered by third party, press CNF to establish a 3 way conversation.
Note: Any party may exit conference by hanging up
Posted on Apr 09, 2009
I have tried every configuration of the wiring I can think of. I have 2 jacks and a Ring Selector for the fax machine.
What is the make or brand/model of the phone you are referring to? Does it has a line 1/2 selector or a ringer selector on the panel?
Maybe the phone you have has a selector on its side.
I need more info.
Best regards.
1helpful
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
I have a NEC Dterm 80 phone system in our office. Not all phones will ring when there is an incoming call, and I want to set them ALL so that they will
Dterm 80 works on several systems, would be helpful if you mention what system you have. Programming lines directly onto a phone is done in system programming, not really something you can do yourself. If your IT person has the programming software, great. Very rare someone on site is tasked with knowing the phone system at that level, because it gets deep quick, and your working on the whole thing, not just one phone.
1helpful
I have a NEC D Term 80 phone. We had a power outage and now my phone does not ring. Is there a way to turn on the ringer?
The only thing I can suggest is unplug the phone from the wall outlet, unplug the cord from the wall and leave it overnight, this will clear any static charge the processor has built up. If by morning there is no change I would replace the phone system because it is not cost effective for repair.
1helpful
Make All phones ring when there is an incoming call
I have a DtermSeries E and the second line blinks but does not rings.
Pick up line ringing Dterm 80
Line ringing preference on our NEC phone
Do not get outside line, just press:
#7579 to turn on, #7576 to turn of
Then press SPKR to exit
NEC Dterm 80 LCD display is defective, where do I get parts? How difficult is it to change?
The common thing on this style of phone is the silver ribbon cable that connects the display to the main circuit board comes loose after being dropped or knocked around and needs to be reinserted. You will need to open up the phone to do this. If this is not the solution then you will either need to purchase a used phone, send it in for repair or use another phone to take parts from.
1helpful
We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Top NEC Lands Phones Experts
Muzahura Frank
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
