Panasonic PV-C2023 20 in. TV/VCR Combo Logo
Dontateamer Posted on Oct 05, 2013
How hook a Xbox up to it - Panasonic PV-C2023 20 in. TV/VCR Combo
tip
How to wirelessly hook up xbox live GOLD
wirelessly hooking up xbox live is an easy, simple process; tech savy or not. first, you will need a wireless networking adapter, which range from 80 to 100$ USD. bestbuy or walmart .com are examples of retailers of such product.
hook up the the adpater into the back of the xbox 360.
if you do not have a wireless router that is currently serving no purpose, you will need.
bestbuy and walmart are once again ideal retailers, and i would suggest a Linksys brand router, hook that up and configure to your router.
no more purchases, except for a xbox membership of course.
turn on the xbox with the Wireless networking adapter plugged in and tap the center "Big X" button, scroll right twice and find "network setting" from there, configure network, and then scan for networks...
if you were successful in hooking up the router, you will find your router as an option to connect to, you may or may not have a specified sercurity.
if you do, you will be required to enter the password you chose.
you should now be connected to xbox live...
want a friend? add gamertag: "xInsanitea" and we can play sometime... thanks for reading!
Hey, I am a mom with no idea what I need to get to set up xbox live. We have an xbox 360 but have no clue what I need to purchase to have xbox live
first off you need an xbox live subscription to use xbox live. Also I am assuming you have a broadband connection. So the best way is to purchase a router and then hook up your computers and xbox to that router via ethernet cable. Here are two links that should help you:
http://www.wikihow.com/Hook-Up-Xbox-360-Live
http://www.ehow.com/how_4532214_hook-up-xbox-live.html
Thank you,
Lee
Trying to get xbox live to hook up where i can go on line
Hook up your internet to your xbox, then follow the step by step instructions under the 'join xbox live' tab in the xbox home screen.
Need to hook up microphones for lips on xbox 360 i have lost instructions
you ahve to use a regular xbox 360 to setup then use the mic
Connecting windstream dsl modem to xbox
Did you get a router, the dsl modem it self wont do much good, you need a router so it can assign your xbox an IP address. You need to have a router hooked up to the DSL modem, and the xbox hooked up to the router.
2answers
How do I disconnect a controller from one xbox 360 and hook it to
press the synce button located on the front of the console. then press and hold the synce button on top the controller. the lights should tell you that the controller has been connected
How do i hook my xbox to my computer. iv tried hooking the controller up with a usb cable but it won't work.
You have to have a modded xbox and you can ftp to the xbox but if you want to hook up to it with the controler you will need the usb drivers from http://www.redcl0ud.com/files/XBCDv107.exe
2answers
The old XBox
hook them up with the crossover cable (the red one)
Hope This Helps,
Maxicube
1helpful
No color on tv when xbox on
Try hooking the xbox up to another tv to see if you get color. If you do it isn't your xbox. If you dont then it's your video cables going bad. Hook a dvd player into the same spot you had the 360 in on your LCD see if you get color. If you dont then its your TV, if you do then it's your xbox video cables going bad.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
