Question about Konica Minolta bizhub 200 Printer
Every page that prints has, what looks like, excess ink along the top edge. How do I fix this?
Posted by Kyle Labuda on
steven brickhouse
  • 19 Answers
Open the right side door and look at the drum unit, if there is a worn spot on the green surface, it will need a new drum, this is normally caused by the developing unit attached to the drum also being worn.
Posted on Oct 19, 2013
2 Related Answers
Anonymous
  • 214 Answers
SOURCE: ink smudges
Pease check:
thet consumables is originals,
drum cartridge is not damaged
transfer belt is clean and not damaged.
you may have problem there, but if not you can try update firmware, maybe its a firmware problem.
first check consumables and if possible try changing them
Posted on Dec 07, 2007
Juan
  • 5 Answers
SOURCE: I need to print on 9 x 6.75 pages, with the
it not only depends on the printer, but on the software you are using to do your text. if you are using office, you must choose orientation manually. If that doesn't work, and for example you are using word art, just leave the page as it is by default and rotate the text. Again, it all depends on the software you are using
Posted on Feb 09, 2011
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
I am getting excess "ink" down each edge of the
by the description I would say that you have fixing problems. Maybe the pressure is not right between fixing rollers or the fixing roller is worn out. However, call service!
Sep 11, 2011 | HP LaserJet 2840 Printer
The printer is not feeding the paper in straight thus not printing straight on the paper any suggestions? thanks Elaine
Have you adjusted the guide so it touches the edge of the paper?
When your page has printed and been ejected, look along the top edge for a "nick" in the paper. This idicates its hitting something while passing thru. look for an obstruction.
May 22, 2011 | HP DeskJet F4280 All In One Printer InkJet
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Alignment amiss and excess ink
  1. Make sure that the printer is idle and the Ready light is on.
  2. Load the media in the input tray.
  3. Print a cleaning page. Access the printer properties (or printing preferences in Windows 2000 and XP).
NOTE: The cleaning process takes approximately 3 minutes. The cleaning page will stop periodically during the cleaning process. Do not turn the printer off until the cleaning process has finished. You might need to repeat the cleaning process several times to thoroughly clean the printer.
If this doesn't help, let me know and I will further investigate.
Jan 09, 2009 | HP LaserJet 1020 Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Ink smudges
Pease check:
Oct 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
Konica Minolta bizhub 200 Printer Logo
32 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
