Toshiba TP55H60 55" Rear Projection Television Logo
Question about Toshiba TP55H60 55" Rear Projection Television
I have a 1998 toshiba tp55h60 that I have been using for my classroom. Recently I tried to plug the wii into it and there is no sound or picture from any of the video/audio in connects. I even tried to run the wii through a VCR by using the coaxel. Still got nothing. The menu screen still comes up and I have tried to reset everything. Is there a simple fix for this or should I just free up some space and scrap it.
Posted by John on
5 Related Answers
Anonymous
SOURCE: tv won't tern on
dont know how to tern on a tv, I do know how to TURN on a TV though...
Posted on Jul 27, 2007
Anonymous
  • 317 Answers
SOURCE: toshiba tp55h60
hard to find..
Posted on Nov 26, 2007
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: no audio brand new toshiba 42xv540u
speakers are muted.
Posted on Jun 10, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
SOURCE: I have a 42" Toshiba Plasma that has sound but no picture?
your y-sustain board is bad
Posted on Feb 28, 2009
5helpful
3answers
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
2helpful
2answers
The power lamp flashes when turned on, no picture???
Ur tv needed a new lamp.Ur current tv lamp,in the tv now.U used the tv about 4 or 5 hours a day.Like the last 1 1/2 or 2 years the tv in used?The lamp life span is over.
1helpful
Fuzzy picture and dark picture and color seperation when hot.
The colors seperating is a convergence problem, as far as being dim this may be related but the TV likely needs service adjustments.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Picture has a "wave" along the sides
I have the parts, very cheap. hill6399 at yahoo.
4answers
My 1999 TOSHIBA TP55H60 picture is not clear.
When is this happen? almost 8yr old the unit. In this case did u change the lamp bafore? Its seems that the lamp is dying. Try to use a DVD as ur imput and post here if it had a diff.? Use Audio/Video input instead of Coax (Cable). Hope this may help you
Design Problem of TP55H60
call tech ..suggest soldering h-drive.
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
