Question about AT&T Quickfire Cell Phone
My phone displays a white screen always - AT&T Quickfire Cell Phone
Posted by mjsurya on
ganesh swami
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
PLZ GIVE YOUR PHONE DETAILS.............
Posted on Oct 04, 2013
Display images are always distorted, display has many stray pixels. After a while then screen goes white and nothing can be seen. Off and on doesn't fix it. . Any ideas?
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
2helpful
Nokia N70 is display prb, white screen
The problem is inside the printer. Turn off the printer and open the replacement ink compartment- move the inks holder far to the left- use a torch to check where the inks holder home and you'll see that there is a sponge a tiny rectangular shape come loose -use the twiter and put back in place (holder).
http://www.fixyourownprinter.com/forums/inkjet/39177
1helpful
2007 razr v3m can make calls but display screen
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
3helpful
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
1helpful
White display
Try repressing the spotlight button, maybe its on.
2helpful
2answers
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
57helpful
6answers
Display problem
i also have the same problem...white screen display
6helpful
3answers
White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Display
THE FIRST U NEED TO DO  is that try to start up  ur phone without memory card. if  it works then take the backup of ur memory card and then format it ...  else u need to reinstall ur system software ....
AT&T Quickfire Cell Phone Logo
Top AT&T Cell Phones Experts
Ekse
William Alequin
Oloyede Monsuru
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
