Question about Microsoft XP Computers & Internet
Device open my pc displays message install package smartwebprintingoc.mci
Posted by vijay bhutkar on
Wesley Hubbard
    New Friend:
    Problem Solver:
  • 15 Answers
Try restart the whole machine or restart the installer, if its a problem or frozen try hold Control+Alt+Delete and the go on "Task Manager" right click the installers name displayed on the Task manager and click End Process
Posted on Oct 27, 2013
1 Related Answer
Scoee Scoffer
  • 162 Answers
SOURCE: Failed to open MCI device. Error Code: 348745
Click on this link: -
http://support.microsoft.com/kb/142731
Posted on Jan 14, 2010
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this will help you.
Thanks.
gylacz
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
Sony nwz-b142 doesn't display in my computer. I already tried installing the device in the control panel and it says device works properly and yet it doesn't display in my computer
This advice could help you if your player works properly and the problem is in your pc only:
At first you should be sure that your USB cable can work.
Then let's see the PC.
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
gylacz
May 03, 2011 | Sony Walkman NWZ-B142 MP3 Player
Everytime I open a Window I get a Windows Serchbox liiking to inttall the File, smartwebprintingoc.msi I Was in a Virus Kill mode ( I Did get the Virus out of my System) But I deleted the...
Go to Start Menu > Run
Type "regedit" and press OK
Use the Find function from the top menu and search the registry for the file name. Delete it when you see it.
Be VERY CAREFUL, once you delete something in the registry it is GONE.
Apr 04, 2010 | Microsoft Windows XP Professional for PC
The Japanese Language Support Package is required
The PDF document contains data in Japanese and needs the support package to display the correct Japanese characters. This is common with files on websites of Japanese companies even thought the document may contain English language also. You can simply cancel and then view the document English text but the Japanese text will not be displayed and you will see various garbage and blank spaces instead. Alternatively, you could simply install the support package. This will then enable Acrobat reader to correctly display Japanese characters. Note: you can also get a similar message if you access a document in Chinese which will then prompt you to install the Chinese support package!
Jul 30, 2009 | Adobe Acrobat 7.0 Professional
MCI Error from SHOWMCIWND The Device Driver is not Ready
Mark
I also had same problem.
Go to
http://www.musiccoach.com/technical_support/errpages/mciset.htm
and install
http://www.musiccoach.com/technical_support/downloads/indeo32fix.zip
open, unzip, install "setup"
After this you can see all video.
Don't forget to set properties of file "charang guitar coach" : open with right click of mouse, open the tab "compatinbility" and set "compatibility mode to windows 98/ME or windows 95
Good playing guitar
Fausto Viegas
Jun 28, 2009 | Charanga GuitarCoach Full Version for PC
Installing hp pos pole display
Download the HP Pole Display Windows OPOS package (sp42198) which will install both the Windows drivers for the device and the OPOS drivers for the device.
The following is the Windows Device Manager screenshot after all the drivers are loaded for the HP USB Pole Display:
NOTE : The COM port number might be different on customer's unit.
Note: The pole display driver will automatically assign the next available virtual port in the system.
HP Pole Display Setup Software Utility
Download sp41532 - HP USB Line Display Configuration Utility from HP website.
Run the file and the Utility will come up as shown below
The COM Port would always be COM1.
Change the selection to the COM port listed in the Device Manager of the unit.
Click on the Welcome Message Tab and Change the Text and Click on “Write to Pole Display
Now the text should be displayed on the Pole Display.
Nov 22, 2008 | POS X POS-X Black Pole Display w/ Serial...
Mp4 player
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
Jan 31, 2008 | Audio Players & Recorders
Computers & Internet Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
