SOURCE: model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
SOURCE: The TV doesn't turn on and it has a purple light.
MAIN BOARD IS BAD...THERE ARE TWO DIFFERENT MAIN BOARDS FOR THIS TV...IF S/N STARTS WITH W2702...USE P/N 5600110351...IF S/N STARTS WITH W2751...USE P/N 5600110493...PART CAN BE ORDERED FROM ANDREWS ELECTRONICS IN CALIFORNIA..YOU MAY CONSIDER TAKING THE SET TO A LOCAL REPAIR SHOP..
SOURCE: where is the reset button
There is no reset button, to reset it, unplug it for about an hour to let it reset itself.
Are you having problem with the set?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
