Question about HTC Computers & Internet
I tried to upgrade my rom from wm6 pro to wm 6.5 pro followed all the procedure step by step as given on this site. was successfull in 1st attempt. i could boot to wm6.5 then wanted to change the rom build. so downloaded new rom available. and followed the entire procedure again step by step. now i am not able to boot. my p3400i gets stuck at the startup screen with HTC logo.
5 Related Answers
Anonymous
SOURCE: o2 rom upgradation
I think the upgrade, when finished would give the instructions to reboot the handheld. Upgrading mine did. It explained I must hit the (On) button and the reset (hole) at the same time.
Posted on Nov 20, 2008
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: upgrading from wm 6 to wm 6.1
there is no official rom available for upgrade u have to switch to un official one's at xda developers but it involves risk
Posted on Feb 20, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
http://forum.xda-developers.com/showthread.php?t=451100
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Posted on Mar 14, 2009
Anonymous
  • 22 Answers
SOURCE: can i upgrade my htc p3400i,with htc touch rom
the answer is no...because when you are about to flash the rom, the ruu (Rom update utility) automatically, and not manually ,searches for phone model.....as this process is fully automatic,,you cannot upload touch rom in p3400i.....but, if you are out of warrenty, you can upgrade to latest rom's available for 'new gene' phones at xda devolopers...
Posted on Jul 28, 2009
Anonymous
  • 195 Answers
SOURCE: TomTom Navigator 6 and HTC Touch Pro 2
Start
Settings
System
External GPS
Programs tab - select COM4
Hardware tab - GPS hardware port = (None), Baud rate = 4800
Access tab - Check the box for "Manage GPS Automatically"
Hit OK
Then open TomTom
Touch the signal bar then the signal bar again
OR
Go to Preferences then Show GPS status
Hit - Configure
Select - Other NMEA GPS receiver
Ensure the baud rate is set at 4800
hit Done
Select COM4:
Posted on Mar 22, 2010
Link for update to WM 6.1 or lates update fo OS WM 6 pro.Send me links for downloads for all software and drivers update for i-mate 9502.Thank you !
Sure, download this file to your PC and unpack it. You'll find a pdf file with instructions. Anyway, connect your device to your PC, which shall have either ActiveSync (for Windows XP) or WMDC (Vista and 7) installed, run the extracted executable file, and follow the prompts. The upgrade procedure will hard reset your device. After it comes back to life, it will have a WM6.1 (v1.77) ROM, which is the last ROM released by i-mate prior to its bankruptcy.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Feb 05, 2011 | i-mate Ultimate 9502 Cell Phone
WM 6.1 flash compatable with Australian NextG network settings?
The GSM/3G bands are hardcoded in the phone's radio chip, for what you can flash your phone to v1.77 WM6.1 ROM. This ROM was plublished by i-mate back in Nov. '08, and it is the most recent ROM released for the 9502 so far.
You see, the i-mate's Configurator application, which you most probably used with the stock WM6 ROM, will still be there. So, your internet and MMS settings will, most probably, be done automatically after flashing your device. If not, just check Telstra's Help page, or call them, to manually set those data.
Just my 2 cents... Carlos
May 08, 2010 | i-mate Ultimate 9502 Cell Phone
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
Hi there, I Like to upgrade in my I-Mate JAQ OS WM 5 TO OS WM 6,1 or 6,5 if its is possible.Please show me how to do this. Thank you, Aleksandar
Hi, I'm afraid there is no offical or unoffical ROM upgrade for your PDA yet (ROM is the place where the PocketPC operating system is stored, and each device model has a different ROM so sadly you cannot use any other Windows Mobile 6 ROMs with your device.). I am giving more details about this issue to make it clear. Still you can follow the forums time to time to check if someone makes a ROM for your PDA. Basic problem is unlike most of the PDAs, your PDA is a non-HTC based PDA. I hope this helps. You can still download some PDA software to use your device more efficiently (Most of the PDA softwares are designed for working on both WM5 and WM6, since your device uses WM5, you won't be having a problem.).
Details of your PDA: (http://www.pdadb.net/index.php?m=specs&id=587&view=1)
Unoffical ROM forum: (http://forum.xda-developers.com/showthread.php?t=349007)
Offical ROM website: (https://www.imate.com/Support_DeviceSupport.aspx?key=48fc9a97-1b91-4350-919d-b4dfdbcb6cbd&cmd=roms)
Apr 18, 2009 | i-mate JAQ Pocket PC
first try this
Mar 14, 2009 | HTC Touch P3450 Smartphone
WM 6.1 pro update for Touch CDMA
go to www.ppcgeeks.com its a free cellular forum and they have all the instructions on how to install roms and flashing and unlocking your phone(s).
Oct 02, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Won't turn on phone.
I would recommend using Pocket PC 2003 version instead. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Below, instrutctions on getting ROM for PPC 2003:
Try www.xda-developers.com and ebay for ROM upgrades. There are many people who unlock these kinds of devices. I don't believe you can upgrade it to WM 5.0 or beyond, but that may be possible. Search for WM versions that include "unlocked" versions. The best bet is a newer version of PPC 2003.
The process is relatively simple. Once you have your ROM on CD or via download, You run it with your device hooked up to your PC via cable/cradle and connected via ActiveSync (3.7 or later). The warning is an improper ROM load could make your device unusable. It is a risk you have to take if you want it to make calls. Toss up: no phone Pocket PC, pocket PC phone, or shiny brick. If the XDA site has recommendations on a ROM source, they are not likely to steer you wrong. They will state emphatically, that you do not want any interruptions in the ROM upgrade process. If you have a power outage or something shuts off for any reason, you will have the shiny brick and be looking for a new device.
Aug 07, 2008 | Siemens SX66
I go to the WM6 and now my SX66 donĀ“t find the signal, plz i need a solution
Jun 11, 2008 | Siemens SX66
Samsung i600 blackjack
Well not quite sure about this one due to the fact my local AT&T office says they are not sure when they are releasing the WM6 update... your local store must be ahead of mine. But I am sure they could help you with the issue. I myself took a risk and updated the OS by browsing the net. I have no problems right now. You might could google it or try the CD that was sent with your phone.
Oct 29, 2007 | Samsung Blackjack SGH-I607 Smartphone
Computers & Internet Logo
57 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
