1995 Ford F150 Styleside Regular Cab Logo
Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speedometer bounces while driving
1995 Ford F150 pickup speedometer bounces about 5 - 10 mph when driving down the road. Can this be fixed with a new cable?
  • Anonymous Mar 29, 2014
    speedometer bounces at 60 mph,replaced speed senor
Shannon Greer
Level 2:
Sniper:
  • Expert 75 Answers
  • Posted on Apr 21, 2009
Shannon Greer
Expert
Level 2:
Sniper:
Answers
75
Questions
0
Helped
51274
Points
236
Your spedo cable is probably just loose which can be fixed by tightening or replaceing. Might as well go ahead and replace it since its a 14 year old truck and its the more sure fire way to fix the bounce.
1helpful
Replace speed sensor in my 240SX 1991 Nissan and the speedometer still has a rapid Shake went on sometimes it turns off most of the time it's off
link with some info about faulty speedometer.
https://wheelzine.com/speedometer-not-working-properly
https://maxima.org/forums/4th-generation-maxima-1995-1999/311797-fixing-speedometer-odometer-work-sporadically.html
This may not be of any help but I had a 94 and the speedometer kept messing up. One day my wife was in it and she was stopped at a red light and it was bouncing around 30 MPH. She took it to the dealer we bought it from. They told me it is run off electrical signal and the alternator was bad. They changed the alternator and we never had the problem again. Just a thought check your alternator see if voltage is good are bouncing around. You can check it at the battery while it is running. I have never heard of anyone else where the alternator effected the speedometer but it is what I was told and they did change the alternator.
I will say I do not remember the MPH being 0 while running.
3helpful
3answers
Speedometer bounces from current speed down to zero (where it sometimes sticks)
It won't be a cable, as it's impossible for a cable driven speedo to perform this way.
It's an electronic speedo.
Check and/or replace the speedo sensor in the gearbox housing.
2helpful
2answers
F150 Speedometer issue
This is your speed sensor. Now i do not know if this is going to be cable driven or electrical because they used both in 95. Your local auto parts store will tell you exactly what kind is in your truck. I just changed one friday on a 94 ford escort and it was electrical. The part was around 20 dollars for the speed sensor.
I have a 95' 1500 chevy pickup ... Cluster issue
sounds like you may have a problem with your speed o gear in trans.
The speedometer needle "wobbles"
the speedo cable needs to be replaced,they wear out internally and start to jump arounr inside the sheathing
4answers
Speedometer is about 20miles an hour off and
most certainly a speed sensor problem!
it may not be pulsing properly or the drive gear is worn etc etc.
Cheers Rob
1helpful
2answers
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
