Question about Konica Minolta Bizhub C550
Red light is blinking after you turn on the machine and it cant go through the menu in copying what could be the possible problem in my machine
Posted by reymark gonzales on
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
Sep 03, 2014 | Mitsubishi XD221U New
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
My mr coffee esspresso machine has to lights red and green they are both blinking and i cant make coffee please help
This is actually a fairly common problem with many coffee or espresso makers. When both lights are blinking just shut the machine off, wait about 5 seconds and turn it back on. It should work fine. If not, give another shout out.
Feb 19, 2011 | Mr. Coffee ECMP40 Espresso Machine
The red drum light is blinking and it will not make copies
HI drum is reach for end of life thats why drum light is blinking you shuld have to replace the drum or just reset the drum counter to run your machine for another life .
thanks
May 11, 2010 | Sharp AL 1631 Copier
Blinking red light wont show image
Is the blinking red light on the PS3 or on the controller. Maybe you could try to reset the machine. Wouldn't hurt. With the ps3 turned off you can hold down the power button on the front of it until it beeps twice. If that doesn't do any thing and you still get no picture you can try it again but keep holding the power button down for longer and it will beep a couple more times. Then if you are lucky you might see a menu pop up on the screen with about 5 options you can play with. If you still don't see any menu or image or even an error message you might be in trouble.
Jul 24, 2009 | Sony Playstation 3 (PS3) Console
Machine will not make copies
Your out of toner and the machine cant set up.
May 20, 2009 | Xerox Office Equipment & Supplies
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Konica Minolta Bizhub C550 Logo
37 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
