Wincor highprint 4915xe carrier error - Office Equipment & Supplies
Posted by Eldo Babaro on
1 Related Answer
daddytech
  • 280 Answers
SOURCE: how to solve transport error on wincor nxdorf 4915xe
usually transport errors mean that something inside the printer is not allowing or not feeding the paper through properly , either a motor isn't kicking on, paper is not being picked up from the supply tray properly or there may be something caught in one of the stop sensors inside the printer that will not allow the paper to pass through properly. unfortunately the only way to fix that usually is to look at every sensor in the paper path and ensure nothing is blocking or holding any of the sensors open if none of those are blocked off then you may have a bad motor on one of the drives that pull the paper from one location to another inside the printer.
Posted on Jun 25, 2014
Wincor nixdorf 4915xe, i get "carrier error" on display, occasionally. what is this error pointing at?
Carrier error relates to ribbon. If ribbon is very loose or not properly installed it will give carrier error. Reseat the ribbon assembly and tighten the ribbon using knob available on top side.
Oct 14, 2014 | Office Equipment & Supplies
How to solve transport error on wincor nxdorf 4915xe
Jun 25, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
CANON ir 3300 ERROR CODE 602-003
Dear All,
I need driver for wincor nixdor beetle /M II Plus, TH230, BA84,80 ? who can help pls.
Jan 06, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Carrier error 41, 44
hi google carrier error , not sure but it could be pressure switch , but it is on google
Jun 21, 2010 | Heating & Cooling
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
1,939 people viewed this question
Ekse
Marvin
Marvin
