Is it loud or different sounding when it's spinning?? Check connections between mcity and the ccu if good and the mcu is good u have bad bearing causing it to not reach proper rpm!!!
SERIAL COMMUNICATION ERROR The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power. 2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). Check connections of the CCU board within the housing. Make sure all grounding switches are engaged. 3. Check the drive system for any worn or failed components. 4. Plug in washer or reconnect power. 5. Verify CCU operation by running a Diagnostic Test or any cycle. 6. Check the MCU by looking for operations of the drive motor. 7. Check the drive motor for powered rotations. 8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
hi, it is a common problem in the classic series of nokia phone...it is cause by corrupted software...try to turn off your phone then unplugged your micro sd ,then turn it on...observed your phone if it will switch off..if same status ,you need this tools ,flash file and gadget to fix your phone... 1.)fbus cable 3110c 2.)mx key dongle with ufs interface 3.)3110c flash file v7.23 (you will get it in this site.....http://www.lsdshka.narod.ru/firmware_nokia.html )
procedure.. connect the phone in mx key dongle using 3110c fbus cable ,open mx key ,tick bb5 then bus check ..if the phone is connected to mx key put the flash file ,mcu ,ppm and cnt ..before flashing the phone and everytime you do flashing always make a back up in pm section and rpl of the phone to prevent bigger damage...now it is safe to flash the phone .after the flashing is done inse the battery and test the phone... if you have no gadget that i mentioned above ,dont do the programming in your phone..go to a expert mobile technician ti fix it.. thanks for trusting fixya and i hope it will help you..
hi, your phone is having corrupted software,you have two option to fix that..first if you have this gadget you can do it it on your own... 1.) activated mx key dongle with ufs interface 2.)ufc cable 3.)5800 flash file ,MCU ,PPM ,CNT
here is the procedure, A.) open mx key B)connect the phone to mx key using ufc cable C.)bus scan D.)if the phone is now connected and you read the info E.)put mcu ,ppm and cnt (warning ,the flash file must be higher than former version because 5800 is undowgradedable,to prevent more damage on its software... F.)back up rpl and pm before fllashing (in mx key thick SERVICE <IMEI AND SECURITY ,ALL SECTION G.)the phone is now safety for flashing ,then wait until its done...
if you have no gadget and tools that i mentioned above ,go to a nearest nokia care in your place ..i hope it will help you ,thanks for trusting fixya
hi, clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure.. using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker... in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya.. goodluck..
hi, first of you need this gadget MX KEY DOGLE and ufs twister box as your interface ,ufc cable2 to connect it in your computer...flash file which contains MCU ,PPM and CNT...its very technical but i hope you will understand it because you did not ask this question if you have no knowledge in mobile repair...
here is the step , 1.open mx key 2.select ufs as interface 3.connect phone to ufc cable ,set to 7.5k 4.thick dct4 (because 6255 is dct4 phone) 5.bus check (because the phone is dead) 6..set your MCU ,PPM ,CNT 7.flash the phone and wait until its done... in case you have no gadget as stated below,go to nokia care center to fix your phone..i hope it will help .thanks
The F11 indicates a Serial Communication ErrorCommunication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Action: Disconnect power and unplug unit. Check wire harness connections to the motor, Motor Control Unit (MCU), and Central Control Unit (CCU). Check the drive system for any worm or failed components and reconnect power and plug unit in. Verify CCU is working by performing diagnostic test or any cycle. Check MCU by looking for operations of the drive motor and check drive motor for powered rotations. Make sure the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors. Replace failed component
with multi box
Attach phone
Lock
press yes to download RM-305************x.unlock_img
now flash your phone with downloaded file (mcu part) with jaf or ufs
return to multi box software ..
Attach phone
Lock
now reflash your phone with original mcu-ppm with jaf or ufs
your phone is ok
