Samsung Digimax A7 Digital Camera Logo
Question about Samsung Digimax A7 Digital Camera
Batteries don t last long?.
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
tip
How to Make a Laptop's Battery Last Longer - 10 steps
These are some tips to make your laptop's battery last longer:
  • Dim your screen
  • Turn off programs running in the back ground that you aren’t using
  • Run off a hard drive or jump drive rather than a CD or DVD
  • Turn your computer off or to hibernate mode
  • Optimize your power settings
  • Don’t use sound
  • Don’t have multiple programs running
  • Keep your temperatures down
  • Defrag your hard drive
  • Get a new battery or new computer
goodluck :)
on Dec 14, 2009 • Computers & Internet
Why Power Tool batteries can't charge to 100%?
Batteries wear down over time. The cells inside them don't work as well at holding a charge compared to when they were brand new. So after using them for a while they begin to last a shorter amount of time.
Lithium Ion batteries last longer and don't wear out as quickly. NiMH batteries are next in reliability. And NiCad have their own issues.
Aug 13, 2012 • Drills
Change battery
should be able to use a charger that you would use on a car a lawn mower battery only last 2 years 3 if your lucky if you don't have a charger it might be cheaper if you buy a new battery
Mar 29, 2012 • Garden
Battery wont charge on a dell anspion1525
Will the laptop power on with the AC Adapter and Power Cord plugged in? If so, the battery is probably dead and won't hold a charge. Batteries don't last forever.
Why does my battery drain so fast on my Samsung Admire cellphone?
maybe you are using too many functions. Try removing everything you don't need or you could get a new battery they don't last forever. Another tip make sure you flatten the battery regularly and then recharge to full from time to time.
I GOT A WA3512 .1 BATTERY REPLACEMENT --AFTER 4 WEEKS, IT IS NOW NOT TAKING A CHARGE. THE RED LIGHT ON THE CHARGER IS BLINKING.
Not only do the batteries go bad, but the chargers as well. If you can, plug in the charger, don't connect the battery to it and test the voltage output with a volt/ohm meter. This should let you know if indeed, the charger is bad. Chargers get hot and don't last forever.
Sep 11, 2011 • Garden
My nokia 2690 is not getting started (on) & not supporting the charger also.its not getting charged.
It sounds like your battery has died. The batteries don't last forever and they eventually start to hold less and less charge. Did you notice the battery starting to last a shorter and shorter time? You probably need a new one.
Jul 22, 2011 • Cell Phones
1helpful
My battery will not keep a charge it don't last 10 minutes/ i like the weedeater but it just don't last long enouh
I had one of these a while ago, the batteries are just cheap. Trimmers also use a lot of energy and battery powered ones aren't the best way to go if you want them to run a long time. I highly recommend replacing it with a good gas or plug in model from your local hardware store, they can help you find the right one to fit your budget. If you don't want to get a new trimmer you are going to be fighting dying batteries every year.
My casio exilim battery shows low battery even after charging completely.
Rechargeable batteries, unfortunately, do not last forever. The older the battery and the more it's been used and recharged, the shorter the life. You will get to a point where the battery will only last 30 minutes or so, and will take only 20 minutes to charge (if you have a charge indicator for you battery).
My suggestion is to look online for a replacement battery. There are many places that sell generic batteries that work very well, so you don't need to spend the extra money to buy a real Casio battery. Just do a search for your battery model number.
Good luck.
Top Samsung Cameras Experts
David Shaub
 Grubhead
Grubhead
Are you a Samsung Camera Expert? Answer questions, earn points and help others
