Question about Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv
Champion model#40048 1500/1200, generator runs but no electricity
Posted by bob cavan on
My Champion dual fuel 9000 watt generator had low oil and it shut off. Upon replacing the oil, it runs for 3 seconds and shuts off.
Make sure it's right on the dot any over fill it won't run .use non detergent oil only so it don't bubble
Aug 08, 2018 | Electrical Supplies
What should be the voltage at the brushes of a running champion 9k watt generator.
might find something here
https://www.google.com/search?q=champion+generator+troubleshooting&rlz=1C1GGRV_enUS751US753&oq=champion+generator+troubleshooting&aqs=chrome..69i57j0l3.10135j1j8&sourceid=chrome&ie=UTF-8
May 24, 2018 | Cars & Trucks
Champion generator won't start and keep backfiring
You need to rest the Valves. We have a guide here: https://www.generatorguru.com/need-help/
And videos on the Valves purchasing page to show you how to do this. Just look up your model to see the video: https://www.generatorguru.com/champion/
If you need any further help let us know and we would be happy to assist you.
Regards,
The Generator Guru Team
Sep 13, 2015 | Electrical Supplies
I have a champion generator model 41552 and when I plug the power cord for 240 volt it trips to breaker on machine
If your voltmeter is registering the 240v prior putting in the twist-lock plug then your have a crossed wire plug or there is a problem with the load.
If not reading the correct voltage then you have problem with the generator's alternator. Example bad regulator or a shorted main winding.
Nov 23, 2014 | Champion International Electrical Supplies
My champion generator model #46596 will run but won't give electric
All breakers OK? Then it could be lost exciter current. Her's how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With the generator running, insert bare wire ends into the AC outlet - one wire to Hot, the other to Neutral. Insert and remove quickly - there should be a flash and power will be restored. If not, repeat until you get that flash. If you are too slow to remove the wires from the outlet after current is restore, the light gauge wire should burn out before the battery suffers damage. Be quick - be careful.
Apr 04, 2014 | Electrical Supplies
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
[email protected]
Jul 02, 2011 | Champion International Champion Power...
My Champion 6.5HP Generator has a gas leak under the gas tank. The gas shut off valve is missing a rivet (one of two). I've got it unscrewed but am not sure how to get a replacement part. I have the...
They have a website at http://www.championpowerequipment.com. Click "support" and they tell you "If you need to order a part please call our tech support line. Our professionally trained technicians will be able to assist with placing orders. Orders ship within 1 business day - orders received before 2:00 PM (PST) will be shipped same day." The number is 1-877-338-0999. They also have many service bulletins thee thay will help solve many problems.
Apr 23, 2011 | Champion International Champion Power...
Champion generater. It seems fuel pump is not pumping the gas . what to do?
First start small Check to see if there is any clogs in the line also check the fuel filter if the pump is broken go to google and type the model number in and that should bring up everything about that and possibly help you find parts for it
Mar 10, 2011 | Champion International CPE 1000Watt...
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Champion International Champion Power Equipment 46515 3500 Watt 196cc OHV 4cycle Gas Powered Rv Logo
298 people viewed this question
Top Champion International Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Champion International Electrical Supply Expert? Answer questions, earn points and help others
