Sound like it could be some "dirt" in the "air-trap-tube", so the machine dont get the signals that says it's empty. This also can also make problems for filling. This "air-trap" is the plastic tube, mounted upwards on the bellow hose, between drum and pump.
Could also be a pressure switch, or pressure sensor problem, but this is not very common:)
SOURCE: not just your ordinary pintrap drain problem
check to see if there is a small coin in the grey drain hose that joins the pump also see if theres a coin stuck in the black sump hose to the pump.you will have to remove the front panel first.two screws underneath the front a one under the soap drawer.the paddles pull out put small screwdriver in the middle hole and pull hard toward you,they will come out also blow through drain hose to see if somthing stuck coins act like a valve and cause inttermittent draining problems,also check pump impeller isnt damaged it may look ok(white).hope this helps.
SOURCE: asko 6221 washer won't drain, now won't fill either
u will hve to get ur control card repaired.the problems u shared with us arises due to faulty circuit control card.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem...
SOURCE: Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
