Question about Konica Minolta Bizhub C550
Normal text document with no background but when printed it appears with a yellow background. My machine is a Bizhub C550
Posted by Haneryco Shikanda on
steven brickhouse
  • 19 Answers
Replace the yellow imaging unit.
Posted on Oct 19, 2013
2 Related Answers
Anonymous
SOURCE: Socket Connect Error on BizHub C550
Select HTML on the Pagescope login page.
Posted on Mar 09, 2009
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: still need help with BizHub C550
tell me whats the problem you are facing plz tell in detail>..........
Posted on Jun 19, 2010
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Jan 08, 2015 | Konica Minolta Bizhub C550
I reset my bizhub c550 and now the copy and print out on a black background
you will need to go through the complete setup procedure again by the book, if that does not work you will need to replace the black iu610. please follow it step by step, even setting the time and such along with printing out all of the management lists, for some reason this machine is very specific on setup.
Dec 08, 2014 | Konica Minolta Bizhub C550
Magental background on all prints looking like a pink papr instead of white
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
Nov 05, 2013 | Konica Minolta Bizhub C550
I am using a Bizhub C550. I want to print an Illustrator file without maing it a PDF. Once, I was lucky to print 8.5 X 11 file using the Bypass tray. I like rinting through Illustrator ai instead of I
The easiet way is to open all trays and load the bypass and tell the machine you loading 8.5 x 11 on bypass.
You can also set it on any tray within the menu of the copier under paper > then select tray > then change paper tray settings. Usually it is set to auto. but you can change bypass to what ever size you want with respect to the spec of the machine.
Jul 12, 2017 | Konica Minolta Bizhub C550 Color...
Hi! my problem is: normal text-documents come out with white text and black background! Should be the other way round! what can I do?
with the document open, go to print, then printer set-up and text color, set to black, background color set to none. Should help
Mar 21, 2009 | Brother HL 1050 Laser Printer
Printing consecutive page numbers on multiple documents
look in applications (mainscreen) and I thinkit's under stamps/overlays. You might even be able to choose what page number to start with
Jan 06, 2009 | Office Equipment & Supplies
Konica Minolta Bizhub C550 Logo
172 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
