Question about RTO Automatic Transmission And Engine Oil Pressure Tester
I have a 1998 ford contour it has a small rubber hose coming from the transmission pan trying to find where it connect to
Posted by Tony gwynn on
victorin1
    Problem Solver:
  • 9 Answers
Hi, this cars have a breathing hose that runs from the pan to the battery box and has no connection. The battery box have two holes at the top where this hose are attached.
Posted on Dec 03, 2013
How do I change transmission filter in an automatic 1998 ford contour 2.0 4 cylinder?
filter is inside the transmission pan. So you might as well do a complete service.
Mar 12, 2015 | 1998 Ford Contour
Could you show me or tell mewhere the transmission filter is located on a 1997 ford contour 2.5ltr. v-6?
You have to drop the transmission pan with gasket to get to the transmission filter. About 5 quarts or so of transmission fluid will come out when you drop the pan. You have to buy a new transmission gasket. Do not reuse the old gasket.
Jun 10, 2014 | 1997 Ford Contour
Leaking transmission fluid from the bottom of my 1998 ford contour
trans pan gasket is a possibility they can dry out and crack outward under pressure
Mar 24, 2014 | 1998 Ford Contour
Where does the rubber hose by the transmission range sensor go to on a 99 ford contour 4 cycl
There is a small vent hose that mounts on a black plastic clip by the battery hold down bolt/ nut., if not properly installed fluid will leak from the transmission, while driving the vehicle, we had a new battery installed and the little hose dropped down toward motor.
Oct 26, 2013 | 1999 Ford Contour
How can I replace a valve body in my ford contour automatic transmission?
Have to remove the transaxle most likely ,
to get side cover off
That is not a home drive way job
Jan 18, 2013 | 1998 Ford Contour
Transmission not shifting when pressing on the gas pedal stop a deadstop.vacuum hose from transmission is still attatched to trans but is disconnected from other end.where does the vacuum hose connect to?
modulator on trans if its at bottom on trans(round object on back or side of trans case,or if on engine it connects to vacuum inlet port ir small pipe on inlet manifold ...even near carb,,,efi,really screws up shifting like youve said
Nov 05, 2009 | 1998 Ford Contour
How to change rans filter on 1996 ford contour
You must remove the transmission pan, the filter is inside the transmission.
Apr 15, 2009 | 1996 Ford Contour
97 ford contour gl, info on transmission pan filter installation?
trans filter can only be replaced by taking the trans apart. absolutely not worth it.
Apr 10, 2009 | 1997 Ford Contour
Help with finding a Steal Heater hose line
Yes, just cut the metal line out, leave it bolted in and just remove the metal so you have enough to slide the bubber hose on, make sure you use a ratchet to titghten the hose clamps down nice and tight.
Jul 26, 2008 | 1998 Ford Contour
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
Top RTO Measuring Tools & Sensors Experts
Harrie
jdthefixer
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
