Shure UT2 / 58 / PG58 Professional Microphone Logo
A
Anonymous Posted on Oct 02, 2013
The on off scitch indicator light flashes red when a new battery
Rick
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Shure Expert 611 Answers
  • Posted on Jul 27, 2014
Rick
Shure Expert
Level 2:
Prodigy:
Answers
611
Questions
0
Helped
162043
Points
680
Contact Shure for repairs.
1helpful
My Lexus Tzora won't move. Flashing red light. In drive? The battery is new, as of today. Does it need to be fully charged to start?
The flashing red light means your battery is defective. 2 of 2 found this helpful. Do you? Seems to be more the battery's fault, indicating the voltage of the battery is off, and then the charger won't charge it anymore because of that, indicating that by the flashing red light.
2answers
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
1helpful
Daughter opened battery area under water accidentally. dried it. red light at battery flashing. Can it be fixed??
The good news is, the flashing red light on your camera means that the camera itself did not short-circuit and still may work. If it's flashing red next to a battery logo or it is a flashing battery logo that could indicate that the battery itself is fried and you would need to purchase a new battery. You can find camera batteries for cheap on websites such as Amazon.com
I bought a second battery (standby as I am going to Africa) for my Inspiron, charged it for about 10 hours until it indicated it is full. However, the power light has been flashing red since. Even when I...
Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd.
Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Top Shure Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Cairns
Mike Cairns
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
