Can you please post a model number for your Frigidaire? Does the lights come on inside or any noise like fans running? Sea Breeze
SOURCE: FRIGIDAIRE TOP MOUNT REFRIGERATOR
If the model FRT18IS6CQG is correct your refrigerator has a defrost thermostat inside the fresh food section where the controls are. Need you to turn it clockwise until the refrigerator stops running. This puts the fridge in manual defrost. About 20 minutes later it should come back on without your help. If not we need to replace the timer. Let me know Sea Breeze
SOURCE: drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
SOURCE: New frigidaire top mount freezer gets partial
if you put your hand up there over the vent can you feel cold air? That is your damper control. You should be able to feel cold air.
SOURCE: Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
SOURCE: 4 yr old Top Mount Frigidaire freezer is not freezing
Even after you had unplugged and started if the fridge is not cooling well then the compressor is not having the right pressure for the heat exchange. The possible problem can be fault in the compressor or lack of gas in the system. check if the compressor motor speed is fine and pumping well, need to use a current test witth a clamp tester. If not check on the contacter relay, the capapcitor. If ok the gas pressure must be checked or refilled. I hope you can follow this out and try. Good day,
