Question about Faberware FSRC100 10-Cup Rice Cooker
Wiring diagram rice cooker - Faberware FSRC100 10-Cup Rice Cooker
WHERE CAN I GET THE WIRING DIAGRAM FOR MY TAYAMA RICE COOKER TRC-10? IT LIGHTS UP WHEN PLUGGED,BUT IT DOESN'T COOK WHEN PRESSED DOEN
Hi and welcome to FixYa, I am Kelly.
I do not have the wiring diagram but... the 2 wires that go to the top of the unit fray and break at the lid hinge point and cause this problem quite often. The 2 wires in the hinge area are for the upper temp sensor. (The floating plate in the top of the lid) If you fix the wires in the hinge area most of the time the come back to life unless the heating element has failed. The heating element will read about 180 Ohms resistance if it is good. The resistance changes a bit as the unit ages.
Try fixing the wires in the hinge then testing the cook button. I usually have extend the wires in the hinge and do a double splice for the NEW wire strip on each wire with heat shrink tubing over the repair.
If this does not work just respond here and I will assist you further.
Thanks for choosing FixYa,
Kelly
Jan 28, 2011 | Tayama TRC-10 Rice Cooker
Power is not going though
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jul 05, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Where do I find sanyo rice cooker ec-503 power cord
heatman101
Jun 26, 2010 | Sanyo EC-503 3-Cup Rice Cooker
Fire between the end connection power cord and rice cooker
heatman101
May 24, 2010 | Zojirushi NRC-18 10-Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Oster rice cooker
heatman101
Sep 08, 2008 | Oster 4724 Rice Cooker
Where can I find a service manual (with electrical wiring chart)for rice cooker w
Where can I get the replacement thermal fuse you are talking about. The Oster service guy said they do not make them!?.NR
Mar 18, 2008 | Kitchen Appliances - Others
Faberware FSRC100 10-Cup Rice Cooker Logo
Top Faberware Kitchen Appliances - Others Experts
Dennis
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
