Question about HP PhotoSmart Office Equipment & Supplies
My HP Photosmart 110a prints misaligned words in the 1/4 upper section of the sheet. As the printing continuos sheet down everything is ok. I had calibrating the printer many times but seems this is not the problem. Thanks for your help.
Posted by Roberto Hernandez on
ONE-Touch-Solution
  • HP Master
  • 1,679 Answers
This is not calibration issue. It could be due to corrupted Drivers. Uninstall and reinstall the printer software/drivers and it should work fine.
Posted on Oct 02, 2013
5 Related Answers
Anonymous
  • 74 Answers
SOURCE: samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Posted on Jul 18, 2008
hashchathy
harsha gayan
  • 246 Answers
SOURCE: Prints alignment sheet every time you turn power on.
please try to reinstall the printer driver
Posted on Feb 13, 2009
Anonymous
SOURCE: Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Posted on Apr 15, 2009
Anonymous
SOURCE: my HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
Posted on May 09, 2009
Anonymous
  • 122 Answers
SOURCE: Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Posted on Jun 22, 2009
Prints on partial page of an 81/2 x 11 photo paper. Prints OK letters fm word.
Instead of using the Letter or factory 8 1/2 x 11 page set up, create a custom page size for 8 1/2x11 and use that in your app for the page set up. Double check your page orientation and the size of the photo you are printing. It sounds like it may be trying to tile the photo because it's too large for the page size.
Sep 14, 2017 | HP Photosmart C6280 Printer
I can not print from Windows 7 Microsoft word 2010, the pages come out blank, can print in excel and other office programs just not documents please help have tried everything
Make sure you are installing CURRENT drivers/software offered by HP for your printer for Windows 7. Get it here:
https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-e-all-in-one-printer-series-d110/4023244/model/4023245
Maybe the issue is not printer related. Maybe Word 2010 needs some sort of update. Windows Update will update Windows OS and other Microsoft products (I have a Windows 7 PC running Office 97, Windows Update treats it like Office 2003 and STILL updates it!).
Or, you could manually install them:
https://www.google.com/search?q=word+2010+update&ie=utf-8&oe=utf-8&client=firefox-b-1
Good luck.
Dec 09, 2017 | Microsoft Office 2010
Print is misaligned when printing avery stock
Dear friend,
If you are using Excel or other spread sheet, you shouldn't print in draft mode. You'll need to use Normal or higher definition.
Regards.
Oct 13, 2011 | HP Photosmart C4480 All-In-One InkJet...
How do I make my printer pick up thicker paper. (Kodak Photo Paper)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You need to adjust the print setting.
1) Open Print dialog box
i) In Word 2003, click File , and then click Print
ii) In Word 2007, click the Office button and then click Print
2) Click Properties .
3) Click the Features or the Paper/Quality tab.
4) Select the paper size from the Size drop-down list.
5) From the Properties dialog box, select the paper type.
6) From the Properties dialog box, select the paper type.
i) In the Paper Type drop down list, click More .
ii) Click the desired paper type, and then click OK .
7) Select the paper source from the Paper Source drop-down list.
8) Change any other settings, and then click OK to close the Properties dialog box.
Visit this link (Adjust Paper Section):-
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01913438&cc=us&lc=en&dlc=en&product=439488
Have a nice day....do not forget to rate the solution.
Feb 19, 2010 | HP Photosmart 3210 Printer
When I try to copy or print I get a "Out of paper"--"Load paper in main tray"-- The main tray is always loaded with at least 24 sheets of 8.5 x 11 sheets of printer paper. What can I do? Thank you
Kindly reset the product.
Turn the printer OFF remove the power cord.
Wait 30 sec and plug the cord
Turn the printer ON
Remove all the papers before doing the above changes
See to it that you feed upto 10 or 25 sheets and not more.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next section.
Jan 30, 2010 | HP Photosmart 3310 Printer
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hi, I have a HP Photosmart C6180 and am trying to send a fax. Have tried fax test - everything seems OK. But when trying to send a fax direct from desktop from Word - it just sits in the print queue...
I not sure I get it???
are you printing or faxing???
if faxing from word ibeleive you need to choose fax then a screen comes up to type in info of phone number, name , etc....
if printing click on print choose the model and it should print.
Aug 11, 2008 | HP Office Equipment & Supplies
Word Settings for Printing Postcards
I found the fix!! Once you have your size settings typed into your page layout screen and applied to the document, click print. Once you select your printer, click on properties (or printer preferences) click on the features tab (the tab next to printing shortcuts) and go to the resizing options section. click on paper size bar and scroll down to custom. once in the screen, give the shortcut a name you'll recognize, type in your dimensions in the provided spaces click save. once you go back to the features screen, scroll back down to custom and select your shortcut that you just created and apply it to both the paper type and paper size. click ok and go back and click ok to print! Hope this makes sense..if not, go to HP's website and type in your product name, type paper mismatch in the keyword search bar and click ont the first link in the found section. It will give you the same step by step instructions....
Sep 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
61 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
