Question about Epson Office Equipment & Supplies
Epson projector keeps shutting off - Epson Office Equipment & Supplies
Peter Okaya
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Indeed this problem can make you go crazy. sinply do the following
1. use the remote and go to projector settings
2. chose power option and set it to high
3. look foe sleep mode option
4. set it to OFF
and you are all done !
Posted on Apr 20, 2018
Lampdeng.com
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 781 Answers
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Posted on Jan 04, 2015
Projector shuts off after while
If an input source isn't detected the screen will blank which looks like a shutdown. What color is the power LED? Is the lamp or temp LED lit?
Manual at: https://files.support.epson.com/pdf/pls6__/pls6__ug.pdf
Mar 16, 2014 | Epson PowerLite S6 LCD Projector
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
My epson emp-74 won't show...the red light keeps on flashing
competitive price.
have a nice day!
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Bulb works, projector turns on, though it immediately shut
check the fan if it works as will as clean the filter.
Aug 18, 2012 | Epson EX31 Projector
Keeps going to double red light shuts down, then it resets and turns on for 5 minutes and then turns off again, what could be the issue? thanks
I've seen this happen almost exactly on a Canon projector. The problem was the bulb. After the bulb was replaced the problem went away.
Please remember to rate this solution to show your appreciation!
Jun 01, 2011 | Epson PowerLite 7900P Multimedia Projector
My epson
the light filter on the blue lcd panel is fried due to excessive dust and heat. it's a common problem with lcd projectors if you don't keep them clean and cool. unfortunately, you'll have to replace the entire optical engine, as epson does not sell individual parts.
Nov 09, 2009 | Epson - PowerLite S1+ Multimedia Projector
Epson 6100i projector password needed
The default code for Epson projectors is 1 7 9 3 while holding down the number button on the remote control, if this doesn't work then the code has been changed. This code will need to be entered whenever the projector is disconnected from the power supply so if you do change it, make sure you keep a note of what the new code is.
Aug 17, 2009 | Epson PowerLite® 6100I LCD Projector
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
4,961 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
