U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
Linda Posted on Oct 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I determine what firmware version my MAXg USR5461 is currently running?
ranchhand
Level 2:
Sergeant:
  • Expert 242 Answers
  • Posted on Oct 02, 2013
ranchhand
Expert
Level 2:
Sergeant:
Answers
242
Questions
Helped
32780
Points
510
The latest firmware release for that router is found HERE.
Be very careful to follow the instructions; especially I suggest connecting direct cable to your router to insure there are no interruptions in transmission. Since I don't have a USR I can't tell you where the current firmware number is located. However, the usual places are directly on the router itself, perhaps on the bottom or rear. Also check the manual, although usually manufacturers don't use this because many times they supply manuals for several models and don't want dated material. It wouldn't hurt to send an e-mail to USR support, most of these companies are pretty good about responding. My suggestion is to flash your firmware only if you have a problem and no other choice.
If your flash goes bad or is interrupted your router will be bricked.
2 Related Answers
A
Anonymous
  • Posted on Nov 06, 2007
SOURCE: user name and password
After trying for a long time i decided to call customer support, they informed me there is no default user name, the only option you have is to reset the router by pressing the reset button for at least a minute than when you go into the configuration ip address you will be prompted to enter a new user name and password
etaf
wayne walker
  • 779 Answers
  • Posted on Apr 24, 2010
SOURCE: i have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Owners manual
I cut the text from your problem: U.S. Robotics MAXg USR5461
and pasted it in to Google.
The first non-sponsored result was:
http://www.usr.com/support/product-template.asp?prod=5461
CANNOT RECALL NETWORK KEY
http://download.cnet.com/WirelessKeyView/3000-2092_4-10614187.html Download and run, and enjoy your internet! Just make sure you're in range of the router in question. Leave feedback!
How do i change my password.us robotics wireless maxg router
ACCESS THE DEVICE SETTING THRU IP ADDRESS ON BOTTOM OF DEVICE IS USUALLY AN IP TYPE IN EXPLORER ADDRESS SPACE THE IP ADDRESS .. EXAMPLE \\199.210.01 .01
OK THERE WILL BE THE NOMENCLATURE PAGE WITH OPTIONS TO CHANGE PASSWORD
I have a U.S. Robotics USRobotics USR5461 Wireless router
I have a US Robotics usr5461 wireless router. It
You might want to check your firmware version to make sure you have the lastest.
BETA Firmware Version 3.93.35.0.9This firmware fixes the following issues:
  • Printing issues with CUPS version 1.2.
USR5461a-v4.3.93.35.09.usr 1.8 MB 06-05-08
Firmware Version 3.93.35.0.8This firmware fixes the following issues:
  • DST (Daylight Saving time) Firewall issue with how IAC (Internet Access Control) works.
  • PPPoE server disconnect/reconnect
  • PPPoE inactivity timer
  • PPTP client disconnect/reconnect
  • backup/restore settings
Note: If upgrading from Version 3.91.37.0.3, follow these instructions before proceeding.
  1. With a thin tool, such as a paper clip, briefly press the RESET button on the back of the router.
  2. Wait about 30 seconds.
  3. Continue with instructions below.
Important: To ensure a successful upgrade, please perform the firmware upgrade from a client that is physically wired to the router. A wireless client may become disassociated from the router during the upgrade process resulting in an incomplete upgrade.
  1. Download this file to a temporary location on your computer's hard disk drive.
  2. To upgrade your USRobotics Wireless MAXg Router with all operating systems, open an Internet browser and enter the router's IP address. The default IP address of the router is 192.168.2.1
  3. Enter your User name and Password. Click OK.
  4. Click Device in the main menu.
  5. Under the "Upgrade Router" section, enter the location of the USR5461-v3.93.35.0.8.usr file in the text box, or click the Browse button to search for the file. Then click the Upgrade button to begin the upgrade process.
  6. When the upgrade process is complete, the router will reboot. To re-establish a connection with your router, wait approximately 15 seconds and click Continue.
USR5461-v3.93.35.0.8.usr 1.8 MB 10-25-06
1helpful
Very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
Router can't be accessed from the WAN
I had the same problem with Firefox 3.0, try using IE
Wireless
What are you trying to connect to?
2answers
User name and password
Default Username - none (leave blank)
Default Password - admin (lowercase)
rate me solved if it helps thx
Top U.S. Robotics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
