Where can I find the instruction manual??
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
SOURCE: No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
SOURCE: Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Koldfront makes a great dual zone cooler. I found you one that holds 18 bottles with
space for 6 bottles of white wine and 12 bottles of red.
