HP LaserJet 5550 Printer Logo
allassane Posted on Oct 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50.1fuser erro hp5550dn
Hp color laser 501fuser erro
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Oct 02, 2013
HP Master
Level 3:
Answers
1124
Questions
Helped
451132
Points
2591
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
How do you replace the scanner cover oh the hp fax machine model 920
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Erroe corde 51.10
Note: Technical skills required:
Laser scanner error:
A. Reseat the connectors between the
laser/scanner and the dc controller PCA
(J801 and J321).
B.Make sure that the laser/scanner
cartridge door interlock mechanism is correctly functioning or not
C.Replace the laser/scanner assembly.
See
D.Replace DC controller.
Laser Scanner assm:
Como resolver o erro da cp5525 laserjet color
please would write English so can i understand you
i can help you do not worry , just go to Google translator covert your message to English , then i will reply you with propor answer
Hope help you
My HP laser jet 1312nfi scanner is not working in lion
Check its copying? if yes reload the drivers with original CD, if no check for the errors.. if its scanner erro XX replace flat bed..
51.10 erroe in my hp laserjet p 3015 printer i have many time power on or but not solved
Error says that printer has a bad laser scanner assembly. Call a tech to make sure.
1helpful
Erro 51.10, hp p4014n
51.XX is a laser/scanner error.
From the operator panel, get to the DIAGNOSTICS menu.
Run the laser/scanner motor component test.
Listen for the motor. You should be able to hear it rotating.
You are probably going to need to have the laser/scanner assembly replaced.
I have a 50.2 fuser erro on our Color Printer HP 4700
The 50.2 code on nearly all HP laser based machines including your 4700 means you have a fuser error. The fuser unit is the assembly that heats up and "fuses" the toner onto the paper. There are a few things you can try including, power cycle the printer and see whether the code resets or try reseating the Fuser Unit. Neither of these will resolve the issue in most cases. Most of the time fuser unit replacement is necessary.
Here is a link for you to see pricing and a picture for your fuser unit. You may want to just buy your own fuser and replace it if your are mechanically inclined. If not you can have a local printer repair shop replace it for you. At least they won't rip you off on the price of the fuser unit. Note that there may be some cheaper prices out there on this unit.
http://www.precisionroller.com/search.php?q=hp+4700+fuser
Good Luck and Thank You for using Fixya.
WheatlandServices
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
1helpful
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
k24674
Grand Canyon Tech
Grand Canyon Tech
