Question about SanDisk Electronics - Others
SOURCE: Trouble Copying Single 7 Gb file to 8 Gb pen drive on OSX Tiger
When you try to copy it to the drive what happens? What error message do you get?
Posted on Dec 23, 2007
SOURCE: I have a .pst file that is 5 GB which I am trying
Two possibilities:
1. you already have more than 3GB of files on the SANDISK.
So, delete some files, or "burn" them to a CD/DVD disk,
so that you have at least 5 GB of "free" space available.
2. the "file-system" (the way that the "table-of-contents" is laid-out on the SANDISK) limits the size of a single file to 2GB.
The "file-system" on your 'C:' drive does *NOT* have that identical limitation (it does have a "maximum-file-size", but it is MUCH larger).
Open Outlook, and "compress" all the folders.
Perhaps, the PST file will shrink to less than 4.7 GB.
If it does, then you can "burn" that file onto one DVD-writable disk.
Posted on Sep 25, 2010
SOURCE: my folders in my usb became shortcut folders, i
Yes, it should be caused by virus. Did you format your USB? If you did not, check whether the folders are not in hidden mode. Please follow those steps. Hope this hleps.
Firstly:
Download "AutorunExterminator" from Cnet http://download.cnet.com/AutorunExterminator/3000-2239_4-10912924.html Extract it --> Double-click on "AutorunExterminator" --> Plug your USB drive now. It will help remove the autorun.inf files from both your usb and the drives.
Secondly:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your usb letter as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and paste it.
Note : Don't forget to replace the letter g with your pen drive letter.
Press Enter
Now check for your files in Pen Drive.
Thirdly:
After that, download the Malwarebytes' Anti-Malware from CNET http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Update it --> Perform "Full Scan" (Note : Default selected option is "Quick Scan")
Posted on May 01, 2011
SOURCE: usb flash drive showing shortcuts inside, help me,
Is this the Problem???
Only Shortcuts,,,,,,
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
Posted on Dec 07, 2011
SOURCE: my flash drive 'Cruzer Edge 8GB' won't Support in my computer ?
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
Posted on Apr 07, 2012
