SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
SOURCE: requiring scanner software for samsung SCX-4216F printer
Dear Sir,
I have Samsung SCX-4216 printer. Printing, Xerox & Fax working is OK, but scan facility is not working because i missed the original software. please give me a solution for get the original software or scan drivers.
With Regards
Mohan
SOURCE: samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
SOURCE: dispaly pannel showing scanner error & also not scanning SCX-4300
my scaner error what i can do in samsung scx 43000
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170
2. Right-click/properties - Compatibility tab.
3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
