SOURCE: Pioneer CDJ-800MKII
Hi, if this cdj 800 mk2 is not loading or it keeps ejecting discs i would suggest you contact your local pioneer repair agent as this is a common fault with the players at the moment and there is a fix for it but you need a special jig to set up a laser replacement and only the pioneer agents have this jig or your player needs a software update but the software update is done via a cdr disc in your case your player isnt reading discs at all so its likely you need a laser pick-up replacement. hope this helps you. regards. paul.
SOURCE: Pioneer CDJ-1000 CD Player jog wheel display
Sounds like a fault on your jogwheel pcb.
if you havent had your player repaired then you can contact me @ www.audiovisualservices.info
Hope this helps you.
Thank you.
