Question about Roland Juno-D
I need to replace the rubbers in my Roland Juno-D.
Posted by Emilio on
5 Related Answers
SOURCE: My sustain pedal does not work on my Roland Juno-D keyboard.
Have you tried the pedal straight into the amp without going thru the Roland?
Does the sustain pedal turn on with the foot pedal or is it a separte stomp switch to turn it on?
Posted on Jun 01, 2009
Fred Yearian
  • 5603 Answers
SOURCE: roland juno-d, keys are either too loud or too
Normally you have to clean the conductive rubber "pills" AND the circuit board traces they get pressed down on.
USE ONLY 99% isoprophyl alcohol on Q-Tips to do the cleaning and be gentle.
Use of other product like deoxit and other contact cleaners will wreck the contact material.
Posted on Jan 12, 2010
djlaplaya
dj LaPlaya
  • 74 Answers
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Posted on May 06, 2010
Fred Yearian
  • 5603 Answers
SOURCE: I wish to know how
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Posted on Aug 08, 2010
Anonymous
SOURCE: I NEED TO KNOW HOW TO SET UP MY ROLAND JUNO D WITH
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
Posted on Sep 14, 2010
How to program arrpeggiator in Roland Juno D
The information is in the manual. You can download a copy here-
JUNO Owner Manual JUNO Manuals Support Roland
Feb 27, 2015 | Roland Juno-D
Where do I install the expansion card on Roland Juno stage
You install the expansion card to the bottom side of the Juno by removing screws. For detailed step by step instructions, I suggest that you refer to page 174 from the manual that you can download from: JUNO-G Owners Manual (JUNO-G_OM.pdf)
Apr 17, 2011 | Roland Juno Stage EXpandable Synth
Where can i get a screen replacment for the juno g ? and how much is it?
You will have to go to Roland parts to get the item and the price will vary depending on your location. The display is going to be expensive... Here is a site...
http://www.instrumentalparts.com/rojuglcdscju.html
$205 it looks like... I would contact Roland directly first. Use google to find their contact info.
Apr 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Some keys on my roland juno d wont sound. How do i fix this problem? Please help.
The key contacts need to be cleaned. They are usually conductive rubber pills in silicone domes that get pressed onto circuitboard traces by the keys. Disassemble to get at the contacts. clean ONLY with 99% isoprophyl alocohol and Q tips. Clean both the pills AND the circuit traces they contact.
Be very careful of cables when opening the unit. Document where all the screws go and their length and threads.
Nov 13, 2010 | Roland Juno-D
I wish to know how to open a Roland JUNO-D synth to access the little rubber strips with the key contacts; I have the typical key-not-sounding problem.
Aug 07, 2010 | Roland JUNO-D Synthesizer
Can I update roland Juno G Old version to new?
Here is the link you need but pay absolute attention to the Please note section in each case as the Juno D LE and the original Juno D are different. If you install the wrong update you will have problems with the keyboard working at all.
Jul 17, 2010 | Roland Juno-D
Feb 06, 2010 | Roland Juno-D
Roland juno-d, keys are either too loud or too
Jan 11, 2010 | Roland Juno-D
May 31, 2009 | Roland Juno-D
Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
Dec 16, 2008 | Music
Roland Juno-D Logo
101 people viewed this question
Top Roland Music Experts
Marvin
Marvin
Vernon Taylor
Are you a Roland Music Expert? Answer questions, earn points and help others
