Question about Sony Cyber-shot DSC-T10 Digital Camera
When turned on the camera vibrates continuously but when turn to picture viewing the vibration stop and when u return to picture mode the vibration comes on
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: Camera vibrates when it is turned on therefore pictures are blurry
seems the motorised lens of your Sony have issue.
should get it rectified without delay if still in warranty.
contact the vendor and sony support.
Posted on May 30, 2009
SOURCE: vibrating and shaking
the sstepper motor of the focus assembly has slipped out of its track. that motor is a very powerful one which can cause the vibration.  once u change the mode to take the picture the motor should run in both direction to make some calibration. you cannot disable it. in the preview mode the optical assembly returns to it closed position and then the motor is switched off.
since it is a cybershot you need to be very careful in handling the camera if you have any plan to open it. it is recommended to be taken to the nearest service centre. any way the wheels might need replacement
Posted on Jul 04, 2009
Anonymous
SOURCE: DSC-T20 Sony Cyber Shot Camera that vibrates like
i thought it's free of charge?
Posted on Aug 27, 2009
Anonymous
SOURCE: vibration problem
Sony has recently discovered that with certain units of its "Cyber-shot" DSC-T20 digital still camera, a symptom may arise in which the camera body may vibrate when it is powered on, due to a mechanical failure affecting the lens, and it prevents the camera user from being able to shoot.
To ensure customer satisfaction, Sony will provide a free repair service when this symptom occurs within certain units covered by the serial numbers indicated in the serial number validation box below.
We apologise for any inconvenience this may cause. Your understanding and cooperation would be much appreciated.
Symptom and cause
The camera body may vibrate when powered on, due to a mechanical failure affecting the lens. This prevents the camera user from being able to shoot.
Applicable model
Digital Still Camera "Cyber-shot" DSC-T20.
How to check the model name and serial number
The model name and serial number are indicated on a sticker located at the bottom of the camera.
Applicable serial number
To determine whether your DSC-T20 camera purchased in Asia Pacific region may be affected, click here to validate the serial number.
Model Name Area Serial No. Range Unit DSC-T20/B AU2 2257001 - 2501900 5,050 DSC-T20/P AU2 2258851 - 2485700 4,700 DSC-T20/S AU2 2261851 - 2501500 7,650 DSC-T20/W AU2 2265751 - 2502100 7,650Period of free repair service
From 17th July 2008 to 16th July 2011.
PLEASE NOTE these serial numbers are applicable to ASIA / PACIFIC check your own country sony website if your serial number is applicable as different regions will have different serial number for the DTS -T20, hope this helps
Posted on Feb 03, 2010
AdiIngel
Adi Ingel
  • 87 Answers
SOURCE: camera vibrates when on unless viewing pictures.
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 04, 2010
Vodafone smart tab vibration mode
1. Find "Sound"
Press the menu icon.
Press Settings.
Press Sound.
2. Turn vibration on or off
Press Vibrate and ring to turn vibration on or off.
When the box next to the menu item is ticked (V), vibration is turned on.
3. Exit
Press the home icon to return to standby mode.
Dec 08, 2014 | Cell Phones
Camera vibrates
better get it to a Sony store.
my cousins also suffered from the same problem.
Apr 30, 2010 | Sony Cyber-shot DSC-T10 Digital Camera
DSC-T20 Sony Cyber Shot Camera that vibrates like a cell pohne. The vibration does not allow for a good picture it all. Could it that the anti vibration system of the camera goes into a full mode trying to...
Hi!
The problem you have is a faulty image stabilizer. It's a well known problem in these cameras. It's a hardware fault and I'm afraid you won't be able to fix it yourself. Usualy it requires the lens unit to be replaced. You should contact your local Sony service center or me at [email protected] - I give the best prices. ;)
I work in a Sony service center.
Hope this helps!
Tom
Jul 29, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Vibrating and shaking
Jul 04, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
The camera keeps vibrating by itself
if its vibrating i would think its something mechanical. this isnt my forte but it sounds like when you turn your camera on the lens covering opens up and for some reason the gears that open it continues to rotate. if your comfortable about tearing things apart look in that area. better yet since its new let the warranty take care of it. this is not a solution just a hunch. let me know how it works out im curious.
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-T10 Digital Camera Logo
Top Sony Cameras Experts
 Larry
Larry
 MikeWang
MikeWang
Paul Green
Are you a Sony Camera Expert? Answer questions, earn points and help others
