If you have long hair and wash your hair in the bath, this is a great product that has a hair grabber to pull all the hair out of the plug hole. The crystals are good for keeping the pipes clean.
You may need someone to help on this one. First thing, check all the 12VDC fuses for your Jayco. It has mini blade style fuses. Using a multimeter or a probe, check for voltage on both sides of the fuse. Next you need to access the back of the switch to confirm you have voltage going in and out when depressing the switch. No power, get a new switch. Yes to power, proceed to next part.
If you know exactly which fuse if for that slide and you do have power, an ohmeter can be used while someone else is pushing the switch the retract. Most of the fuses are 20A, so you should be getting much less. You can also do a comparison between each of the slides. Keep in mind the bigger slides are much heavier so the amperage draw will be higher than smaller and lighter, but still under 20A. If no answer meter or amp clamp type of meter, a multimeter can be used on the DC reading and watching the voltage drop as the switch is pressed. If you do not have amperage or voltage drops, might be a loose or cut wire. If you do have drops and nothing happens, most likely the motor has seized and will need replacement.
.There are a few different installation manual available through Thetford Download RV Product Manuals Support Portal Thetford
follow this link and select your specific model to download the manual you need.
Here is a link I found to help you. I have fixed a few and replaced some for various camper and motorcoaches but not having it in from of me make it difficult to diagnose. This link gives a list for many issues. http://howtomendit.com/search.php?keywords=thetford
this link is for the manuals available from Therefore.
http://www.thetford.com/customer-support/product-manuals/
take the camper to a jayco service center and get the correct replacement items for that camper then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
