Question about Saratoga Spas Pool & Spa
When I want to start the pump, I hear a click inside the panel but the pump won't start + three lights a re flashing on the board!
Posted by Raymond Hardy on
Jason Dinscore
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
Check the voltage at the back of the pump. If your getting the correct voltage check to see if the motor is free. you can do this by removing the small shaft cover at the back of the motor and try turning the shaft with either a screw driver or wrench, depends on the motor. If it is free check the starting compositor. (a black on will have a dot where the wires go, if it black, blown out or leaking oil it is bad. A silver one is not always easy to tell with out a tester. If you remove it and set it on a level surface, flat bottom side down, and it rocks it is bad). If it is good and your sure your getting the right voltage and the motor spins freely your going to have to replace the motor or have it rebuilt.
If your not getting voltage and the jets indicator icon or light is on you may have a bad relay on the board.
If your still having the issue feel free to contact me and I'll walk you through what I can to get you fixed.
Posted on Oct 27, 2013
My normal and Eco light keep flickeing and there is still water in my filter
Hello. That flashing combo of lights is an error code telling you that something has malfunctioned. Most likely, from what you describe, the drain pump is clogged or jammed. I need the model number for a more exact diagnosis of the error code--its a digital code--the lights will flash a certain number of times, usually. The clue here is the water left standing in the tub. It means the drain pump failed to evacuate all the water out. When you cancel/drain, do you hear the drain pump turn on? If so, then the main board is activating properly and sending 120volts to the pump. Probably the pump is clogged with food or debris, and/or the drain hose is clogged. If you don't hear anything, then the kick panel(below the door) must be removed, the pump, wiring, main board must be checked. Check the filter inside the floor of the washer--if it's gunked up, the main pump can't spray properly and the drain pump can't pull water out.
Aug 19, 2015 | Kelvinator Dishwashers
Hl61a750a1fxza tv wont come on led light flashes then i hear a click and all three lights flash
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 06, 2014 | Samsung Televison & Video
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Refrigerator won't run.....when I plug it in all I hear is a clicking noise in the control panel coming from a small white box with a flashing green light and the blue filter line jumps. The only sign...
It may be stuck on defrost cycle due to a bad timer... is there an adjustable switch that you could adjust it should start up... let me know...
Jul 20, 2011 | Samsung Refrigerators
I Have a 94 cherokee country with a 56028297 ecu,it has no power at the grey wire at the ecu,it does flash sometimes and I can hear the relay work sometimes. I can bypass the fuel pump relay circuit and...
If you hear relays clicking sometimes and the jeep won't start, at those times, is the check engine light illuminated on the dash, or not? If no check engine light is on the dash, at times when the jeep won't start, your ecu is in need of repairs. The ecu sends power to the ignition and fuel relays and when the ecu starts to malfunction, the relays usually start clicking.
May 11, 2011 | Jeep Cherokee Cars & Trucks
My samsung hlr6167w will not power up. It sounds as though the lamp is trying to strike, however it never does come up on a picture. After several minutes, all three lights on the front power cirle (Lamp,...
All three LED lights flashes,u hear alot of clicking sounds too?Yes,ur tv the Ballast board is dead too.This Ballast board job is only to ignite the tv projection lamp only.Replace the Ballast board,should solve this problems.
Apr 17, 2011 | Samsung HL-R6167W 61" HDTV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Mar 21, 2007 | Kenmore 24 in. 17019 Built-in Dishwasher
Pool & Spa Logo
60 people viewed this question
Top Saratoga Spas Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Saratoga Spas Pool and Spa Expert? Answer questions, earn points and help others
