Remove the yellow drum, while looking at the yellow magnetic roller just below you will see a small Chrome looking section near the front of the unit where the drum was on the chrome is a small square where the drum density sensor is clean it out with air, if that does not work, then swap it with a different color and see if the code changes to that drum. wire connector for that senor is in the front.
Remove the yellow drum and gently clean the senor behind it tiny small square on the chrome looking assy. near the front of the where the drum would go, or its bad worse case the main board
Remove the cyan drum and clean the very small sensor with a brush or can air. The senor is a tiny square on near the front section of the drum and behind when you remove the drum you will see it. If that does not (DO NOT USE A VACCUM CLEANER) The static electricity fro the vacuum cleaner will destroy it.) need to replace the drum or the sensor worse case to image control board that the sensor talks to. (swap a drum see if the changes it)
