Televison & Video Logo
aschichler Posted on Oct 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture freezes or breaks up - LN Samsung Televison & Video
Russ Hill
Level 3:
  • Samsung Master 4,057 Answers
  • Posted on Oct 02, 2013
 Russ Hill
Samsung Master
Level 3:
Answers
4057
Questions
10
Helped
1177830
Points
12696
Free view or other device. freeview signal is not strong enough. if you have a booster on aerial change it for a new one. after awhile they weaken the signal and not boost the signal to the tv.also check cables. and aerial if looks damaged.
Picture breaks up/freezes weak signal message,
Constantly? Once in a while? If it does it without ever working, it sounds like the tuner is bad. I would not try servicing anything inside the TV. They're just not made for that anymore. I did it for 20 years. You could connect an external antenna, doing the scan, and see it if works that way to rule out a cable problem, or having the cable co. check the dBmv level.
Toshiba 26AV502U, sound breaks up, picture freezes, then fades, and then sound comes back on as staticky, with no picture.
Ur Tuner board have problems,it dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Screen freezes and breaks up
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
You can fix this yourself quite easily!
My digital tv keeps freezing it is an Alba TV and we live in bournemouth and it says we don't have coverage at the moment but we get all the chnnels its just every now aqnd again the picture jutters and...
Because you are receiving digital transmissions, if the signal is too weak your picture will break up and pixilate. In the days of analougue you would just get a snowy picture. If you are getting the channels, you might want to consider investing in a booster and a digital antenna. Install the booster as near to the antenna as possible to get the best out of it.
Cannot tune my evesham tv channals since analogue switch off, have re-tuned several times and fitted a new aerial but still get picture breaking up and freezeing and sound dead spots
The breaking up and fezzing is only due to a weak signal. The only fix if you are not using it is an outdoor antenna. Please take a moment to rate my answer. Thanks..
Panasonice TV freezes and stutteers off of cable when in HD
if the picture keeps breaking up and pixelating it is normally a reception issue rather than a problem with the tv.
Display breaks , scrambles and freezes!
Gee, perhaps a virus scan or spyware scan is in order.
Until this post is removed, DO NOT OPEN the attachment above. Common exploit.
Blurry Screen
The bottom is blurry because some of the anti-freeze (clear ethelyne glycol) has leaked out. This anit freeze needs to be replaced or the CRT will get too hot and break. It will also clear up the picture.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
