Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint w640 F000 error code
Washes fine but dosent dry
Posted by ian hensher on
ernesto cuadra
    Top Expert:
  • Hotpoint Master
  • 12,223 Answers
See this mean :Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Read more: http://www.appliancepartspros.com/repair-help/hotpoint-fault-codes.html#ixzz2gUdlkOnE
Posted on Oct 01, 2013
3 Related Answers
Anonymous
  • 66 Answers
SOURCE: H20 errors on Hotpoint WD640
this is normally a water valve problem
Posted on Jun 16, 2008
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: hotpoint washing machine
I really need more information here, but hopefully the following covers manty of the possible scenarios.
Do you hear a motor spinning during the time the drum should be turning?
If you hear a motor spinning inside the machine then there is a good chance that the drive belt has simply come off. You may be able to just take the lid off michine (My article http://www.fixya.com/support/t1543617-door_seal covers how to do this), hook the belt over the small spindle on the motor and then put it on the big wheel on the back of the drum by placing it over one side of the wheel and spinning the drum to draw it around the rest of the wheel.
Now, if this is the case, you are going to have to ask yourself why it came off. Sometimes this will happen if you had a very heavy load in the machine and the spin cycle threw the machine all over the place, so what was the machine doing on the last occasion it DID work?. Sometimes, the belt comes off because the drum bearings are worn out and there is movement in the drum. To check for this, open the front door of the machine, put your fingers on the drum on the inside and try to lift the front of the drum upwards a little. Bear in mind that there is an outer drum, with the drum that spins inside it and what you are feeling for is the inner drum moving inside the outer one, this will be obvious and "Clonky" if it is worn out. You are not looking to see of the whole drum assembly rocks smoothly inside the chassis, It is supposed to do this. If your bearings are worn out and this has caused the belt to come off, it may well be accompanied by a small, but worsening leak from the back of the machine as the water slowly leaks more and more through the bearing. I'm aftaid that if this is the case, then, depending on the age of the machine it may be time to scrap it. Certainly a bearing replacement is possible as a DIY job, but it is a real pain and not for the faint hearted.
So then, on to the scenario where you CANNOT hear a motor running during the wash cycle when the drum should be turning. This is probably the motor faulting out. Once again, a few checks: does it NEVER run, or will it still spin the washing? Your motor will have up to 4 electrical windings inside it, One for the standard turning motion when there is water in the drum during a wash and up to 3 more that kick in at various stages of the spin as it gets faster and faster. If it still spins, but will not wash, then it is almost certainly a burned out winding in the motor and you have to replace the whole motor. This will cost you (as a rule of thumb) about 25-40% of the cost of the machine when you bought it.
If the belt is on but the motor does nothing at all on any cycle, there might be a loose connection on the back of the motor (A plastic connector block with around 6 wires clips into the back of the motor, check it is firmly in place). Or, the brushes in the motor may be worn out. You can get separate replaceable brushes for most motors. If you can replace an altenator on your car, you can replace a motor on your washing machine, the principle is exactly the same. If you get to the point of taking the motor out, give it a good physical inspection, looking for burn evidence on the wires of the winding, water drip damage AND have a good sniff at it. If you smell that horrible burned wire and plastic smell, you know that the motor is going in the bin.
Posted on Feb 15, 2009
wildwest1959
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
I HAVE AN ECOSYS FS- 6525MFP KYOCERA COPIER PRINTER. IT DISPLAYS ERROR CODE F000 WHAT CAN I DO TO RESOLVE THE PROBLEM?
Code
F000
Description
Main PWB - operation panel PWB communication error
Causes
Defective main PWB.
Defective operation panel PWB
PWB = printed write board
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=FS6525MFP&code=F000
Nov 07, 2017 | Kyocera Office Equipment & Supplies
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Ho heat when drying cycly all else is ok. faolt code is f000
see the error mean:God bless you
Oct 01, 2013 | Hotpoint Aquarius WD640 Front Load...
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Please can you advise what the error code f13 means on hotpoint wdd960 washing machine? I have notived that it often happens on the drying cycle of the 60 minute quick wash dry programme. Is it safe to...
its the dryer fan thermostat, faulty. the unit will turn off if it does not read the thermostat and that's why you have a code. I would say its safe to use but would have the thermostat replaced. here is a video on how to replace the heater. https://www.espares.co.uk/advice/careandmaintenance/how-to-fix-an-f13-error-on-a-washer-dryer-hotpoint-indesit and these are the sensors. https://www.partmaster.co.uk/washing-machine/wdd-960-k-uk-f069442/thermostat/catalogue.pl?shop=hotpoint&path=52516&model_ref=967828&refine=thermostat, hope this helps.
Feb 27, 2018 | Washing Machines
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
80 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
