Follow this steps and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped
circuit breakers or blown fuses. An electric dryer uses two circuit
breakers or fuses, and if only one of two is tripped or blown, the dryer
might still run but not heat. Sometimes the power cord disconnects or
burns at the dryer, if this is the case, the wiring and the terminal
block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer
overheats, in which case the dryer will either not run at all or stop
heating. The fuse is usually located on the vent duct, inside the dryer.
A blown fuse will show no continuity when measured with a meter. Before
replacing the fuse, make sure the blower wheel is not broken or
clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
SOURCE: The dryer heat works but the drum is not spinning.
Raise the top lid and inspect the belt. If it is broken, replace it.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
