Question about Samson Music
Peavey 400bh serie wrong Fuse and smoke - Samson Music
I need to know what size fuse for a peavey XM-6 300 H series I need to replace
It should be a 5 amp fuse, and usually states that around the fuse holder on the rear.
Oct 14, 2015 | Peavey Music
Schematic for peavey standard pa mixer amp 260 series
Contact Peavey customer service at this link-
Peavey com
Jul 21, 2015 | Peavey Music
Schematic diagram of peavey musician mark III series
If you contact Peavey Customer Support at 877-732-8391, they'll send you what you need. Their contact page is Peavey com
Feb 03, 2015 | Peavey Music
Peavey XR series 600 may have been left on without one speaker plugged in, what is the likely diagnosis?
Out put amplifier is defective. If it was protected by a fuse - then look for a fuse that is blown.
Sep 27, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
If I'am powering 2 Peavey 4 ohm bass binns, then linking, from the base bins, 2 15" 4ohm cabs, should my selector switch be in main L and R mode ,or Bridge mode for maxium output and performance,...
You CANNOT power 4 total 4 ohm speakers from this unit without special configuration. The lowest you can go is 4 ohms per side, which would be one 4 ohm cabinet per side. You would have to do a series parallel arrangement with the resources you have... two Peavey's in series and that combination in parallel with two 15's in series...
This is a VERY unsafe configuration with this mixer. ALSO please read my tip on here in regard to PMP mixer grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Frankly, forget about maximum performance unless you want to risk blowing your mixer...
If I were you, I would put the two 15's in SERIES as 8 ohms on one of the channels and the Peavey's in SERIES as 8 ohms on the other channel.
You would be well to heed this warning as I have repaired a bunch of these units. Be careful of any poor speaker connections as there is an insulation breakdown problem in the power amp circuit board if a speaker becomes intermittent. If something fails DO NOT replace the pwer fuse as you will do more damage.
Nov 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Power supply problem
Use the series light bulb trick when trying to first power this up. Use a 150 watt bulb in series with the 120 volt power to avoid damage and blown fuses.
Jul 02, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
59 people viewed this question
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
