Question about HP OfficeJet 4215 All-In-One InkJet Printer
How to increase the font size in tally 7.2 please guide me
Posted by dharampal fushe on
4 Related Answers
Anonymous
  • 115 Answers
SOURCE: Change font size
Two things you can try!
1.From your Browser you can change text size in the browser.
I am using Internet Explorer for this example
Click on View from the top tool bar, Select Text Size.. you can increase and decrease the text size of a web page.
2.Before you print check Print Preview and Increse the page size.
My Browser defualt to Shrink to Fit,
I can change that to 120% and it will print the page very large.
Most programs in Windows will offer a Print Preivew
there you can make adjustments, and this can also be accomplished with Page Set Up..
Hope this Helps
Posted on Oct 24, 2008
Mr fix.it
  • 78 Answers
SOURCE: how do I increase font print size for a printing
you will need to increase the size from the program you are using generally if you go to edit font. the program should give you alternate sizes to change.
Posted on Feb 24, 2009
Anonymous
  • 53 Answers
SOURCE: How to increase the font size when printing?
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
Notepad and Microsoft Word
Please perform the steps given below, if you are printing from note pad nd Microsoft word:
Click on Format.
Click on Font.
Select the desired font under Size.
If you are printing from any browser, then I request you to perform the steps given below to change the font settings in differ browsers.
Following are the instructions to decrease or increase the font size in various browsers:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Posted on Oct 04, 2009
rmcconnel102
SOURCE: the size of the font
You need to download an update to your HP printer - go to www8.hp.com/ca/en/support-drivers.html
Posted on Jul 05, 2011
How do I increase font size
hi Sharon.
it would be nice if you had of said on what.
but try this.
Click View, select Zoom, and then click either Zoom In Ctrl ++ or Zoom Out Ctrl +- to increase or decrease the text size. Note: To reset the font setting back to its default size, hold down the Ctrl key on your keyboard and then tap the number 0.
How do I enlarge or reduce the font size on my web browser? - AOL ...
https://help.aol.com/.../how-do-i-enlarge-or-reduce-the-font-size-on-my-web-browser
How do I make the font size larger on my computer?Fig 3Click on or press 'Alt' + 'Z' to select 'Change the size of text and icons' under 'Making things on the screen larger'.Select or 'TAB' to 'Change Display Settings'.To change your screen resolution, click to select and drag the pointer or press 'Alt + R' then use the arrow keys, Fig 4.More items...Windows 7 and 8 - Making text larger ' My Computer My Way
How do I increase font size on laptop screen?Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.Choose one of the following: Smaller - 100% (default). ...Click Apply. To see the change, close all of your programs and then log off of Windows.How do I increase letter font size on my new laptop? - HP Support Forumhttps://h30434.www3.hp.com/t5/Notebook-Video...increase...font-size.../1286313Search for: How do I increase font size on laptop screen?
How do I change the font size of my email messages?Change the default font, color, style, and size for messagesOn the File tab, choose Options > Mail. ...Under Compose messages, choose Stationery and Fonts.On the Personal Stationery tab, under New mail messages or Replying or forwarding messages, choose Font.More items...Change the default font or text color for email messages - Outlook
or you could read up more at this link.
How do increase font size Google Search
Nov 22, 2017 | Computers & Internet
How do I INCREASE the size or my fonts
Hi lingene...
I have to assume (because you did not say) you want to increase your font size in your email program.
If this is so (and your using hotmail as I am) you will start your email...when the program opens look to find a small pair of sissors on the page...in that line you will see the sissors,font name,and font size...click on font size and change the size of the font to the size you want.
The larger the number the larger the letters will be.
If this is not what you want please re-submit your question with the right program you want to increase your font size in.
Please take time to rate me
Sep 06, 2011 | Computers & Internet
I have installed Tally 9 in my laptop. The operating system is Windows 7. Now when I try ti create a Company, it gives error massage " Exiting Tally ! Error in TDL. Part:Basic Company, Insufficient...
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
May 02, 2011 | Computers & Internet
HOW CAN WE INCREASE FONT SIZE IN TALLY ERP 9
Pres Ctrl+ up the croll button from your mouse.
If you need more information, reply me soon.
Thanks
Feb 25, 2011 | Computers & Internet
How to change fonts size in tally 7.20
HI,
There is an Utility in your Windows.
If you insist i show you but it may be risky Overriding your Original Fonts..
Press WinKey + R it will start Run.
Enter "EUDCEDIT" w/o ' " ' and press enter an Hidden Windows Font Utility will appear.
Select the Fonts you want and override it to "Times New Roman"
All the Fonts in Tally uses Default System Fonts.
GOODLUCK
Jan 19, 2011 | Computers & Internet
How i can increase the font size in tally ? kindly help.
Go to display properties then go to setting and then advance and change the dpi setting from 96 to 120.
Jan 28, 2010 | Tally T6218 Matrix Printer
How i can increase the font size? kindly help.
the easiest way to increase font size is from the computer modifying the font size in the original document ...
if teh document it is in a format that do not accept this kinda modification ...you will have to select all and move it in Microsoft word....here you can modify the font size,,,as you please...Another thing to keep in mind is that after that you will have to rearrange a little the document to fit well in page ...also if the font is increased the document size will be too and it will not fit in the same number of pages...for multiple pages documents ...and will be more than one for single page document ..
I'm using tally 7.2, while printing cheque font size is very small how i can increase the font size? kindly help.
to increase the font size in the printing cheque is just simple go on to (or) press F!! key on the cheque printing option will available on there on the give yes . and then some kind of list will available on there on the list read the sentence one by one the font increasing size is available on there give the correct font size as a number for example (60)
Jan 21, 2010 | Tally T6218 Matrix Printer
My font size suddenly decresed of tally software
at the desktop right click and go to the properties. Go to the settings tab. then change the screen resolution.
Jul 20, 2009 | Tally T6218 Matrix Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
907 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
