SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
SOURCE: I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
