Question about Epson Stylus C43SX InkJet Printer
Ink indicator lights
I cantprint coz if ink indicator lits
  • Epson Master
  • 511 Answers
It's mean "ink out". Not actually "inK", but ink level counter reached zero. If using original ink tank, just replace with new one. If using "hardware resetter", reset ink level counter. If using CIS ink tank, it will be auto reset.
Remember, it's program not actual ink. So, if you reset it, ink level will show full, even if you didn't refill ink tank.
Posted on Oct 02, 2013
Anonymous
SOURCE:
Orange ink light keeps flashing
HP Desk Jet 940c orange light flashing
Oct 01, 2014 | HP DeskJet 940c InkJet Printer
I replaced my black cartridge and now my ink/paper light remains lit and when i press it, after a few noises, the green power light begins to blink. i have recently replaced the color cartridge as well.
It is important for you to post the make of your printer. Anyway, it sounds like your new cartridge is faulty, which is not unusual. First of all, turn your machine off, unplug it, wait a minute, then plug it in and turn it on. If the problem is still there, try another new cartridge. If the problem goes away, get a refund for the one you just replaced.
Feb 17, 2011 | Office Equipment & Supplies
I recently recieved a new 7000 printer. I was not given any directions. The IT department set it all up . They told me it would use the initial ink cartridges pretty quick. On the front of the machine the...
The lights indicate you are out of Magenta and Black ink. Replace the carts. When you purchase them, make sure to buy the XL versions, as they have a much lower cost per page.
Sep 29, 2010 | HP Officejet 7000 Wide Format Printer...
I bought a Canon Pixma MP250 about a month ago. Is it normal for the color ink to already be gone? The orange indicator light for the color ink is lit.
color ink is like water... it just goes... ink is the most expensive liquid on planet earth... even more expensive than oil from the middle east... so if you are using it... it will go pretty fast... your best bet is to try and get some high capacity cartridges...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 22, 2009 | Canon PIXMA MP240 All-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My brother printer is leake the ink
i would reccomend only using brother cartridges and not refilling them yourself as they can leak and therefore not be worth the money you save.
Apr 24, 2009 | Computers & Internet
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
Printer Ink wont work!
HI~ First Check your ink..if you using compitetor ink or CISS ink , Remove The Rubber that are in the Ink Cattridge there, Coz When the print head **** the ink from catrige with pressure it will stuck the print head from spraying the ink out...  After Remove those rubber that are on the ink catrige you need to clean it to release those presure that build coz of those ink catrige build....                                                   If it dont work your print head need to be purge and you need to get in Maintenance mode...then coz you are using generic ink it maybe have spray to other part of the printer the ink Sensor is very close to ink absorber and the Generic ink usualy leak coz the design are not good but it is cheap and you need to know how to use it...
Dec 18, 2008 | Brother Multi-Function Center MFC-240C...
Overiding Empty Cartridge error for Dell A10 962
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus C43SX InkJet Printer Logo
472 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
