Computers & Internet Logo
A
Anonymous Posted on Sep 30, 2013
Nokia 3232c-2
Code phone
1helpful
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
1helpful
How to unlock a nokia 2330c-2 phone
Get the unlock code for NOKIA 2330C-2 at here
Simpleunlocking.com/nokia-2330c-2/rs16wp9/ and unlock it step by step using the instructions below:
Nokia 2330c-2 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 2330c-2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 2330c-2 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2330c-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2330c-2.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2330c-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2330c-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2330c-2
Dec 08, 2011 • Cell Phones
91helpful
18answers
NOKIA 101 SECURITY CODE FORGOT, IMEI-1, 359069046790244, IMEI-2, 359069046790251
NOKIA 101 SECURITY CODE FORGOT, IMEI-1, 359737046783746, IMEI-2, 359737046783753
17helpful
4answers
I forget my security code on my nokia 1661-2, how can i reset it to default without using it? Nokia 1661-2 IMEI # 354198038352831 RH-122
Hello Irfan,
Switch off the Nokia 1661-2 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 1661-2 Cell Phone. Enter the default code 12345 or 00000.Your Nokia 1661-2 Cell Phone will be unlocked.
2helpful
3answers
My mobil is lock model5000d-2
Is it Your Phone Locked To Network Or Security Lock,It locked to Network means You cannot use with Other Network Sim card,You can find that By inserting Other Network Sim card.....It accepts means It's Unlocked from Network LOCK and You can use with any GSM Network,So it's Need some other LOCK unlock,If it not accept Other NETWORK Sim card in the Phone While insterting Other Network Sim card means ..It's Under Network Lock,You have to Unlock it Get the Unlock code and instructions from here
Mobileunlocksolutions.com and Unlock it from Network Lock ,then use with any GSM Network Sim card.....You can Try 0000 or 1234 as default code to Unlock from Security or Password lock,It not works means call the service provider get the master reset code and reset from Security Lock.You can follow the instructions Below To UNLOCK from Network Lock,You need to specify the Network and Country It locked now,to get the code...
Warning : Do not enter any wrong unlock codes on your Nokia 5000d-2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5000d-2 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5000d-2 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5000d-2.
4 - The Nokia 5000d-2 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5000d-2 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 5000d-2
Each Nokia 5000d-2 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5000d-2 mobile phone using the form above.
Ricoh aficio 3232c SC 571
ricoh aficio 3232c eror code sd 195
17helpful
6answers
Forget my mobile security code(Nokia 5130c XM)...Plz Help
4745066750 try this. it is your master code, hope it helps
570 code
Did you mean 3228 or 3235 or 3245? can't find that model or the code. On the 3224C a 570 is fusing oil end. It is a level a code and has to be reset after adding oil.
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
