Question about Just Wireless Bluetooth Headset Wireless Headset
I have a HTC-F5151, his device Bluetooth can not pair on my cellphone
My htc f5151 crashes
Not sure exactly what you mean, but if there is no movement I'm thinking your digitizer (or touchscreen) might have died.
Jan 16, 2014 | HTC F5151 Freestyle AT&T 3G Mobile Phone -...
Can i get wifi on my htc f5151
that's an kernal problem contact HTC and tell them your problem they'll help you.
Jan 19, 2013 | HTC F5151 Freestyle AT&T 3G Mobile Phone -...
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
When i tap to pair a device through Bluetooth .. i always read that the device isn't supported i tried to pair laptops,cellphones, etc nothing worked please i need to find a solution .. thanks in advance...
The only thing that you can pair a WP7 handset to is a headset, everything else is not supported, hence your problem! There is no fix as this is not a fault but a feature and we are not sure yet whether this feature will be included in further updates. Thanks
Jan 02, 2011 | HTC 7 Mozart Cell Phone
How do i pair up mu htc hd2 with htc bh m300 as i bought new one its not been showing in my device
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Oct 08, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
My HTC magic mobile Bluetooth is not working
Hello
What you have to do is to is to open the bluetooth menu on your HTC phone and touch the bluetooth logo to put on the bluetooth radio.
Highlight add a new device,your HTC phone will search for bluetooth device that are within that range and when you see the name of your bluetooth device appear on the screen press next.
Enter the bluetooth device passcode,this can be found in the device owners manual.if the passcode is accepted then press done.The pairing process between your HTC phone and a bluetooth device is complete.
BEST OF LUCK
Jul 06, 2010 | Cell Phones
Just Wireless Bluetooth Headset Wireless Headset Logo
23 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
