Question about Roberto Cavalli Clothing Accessories
Lens scratched and arm is broken - Roberto Cavalli Clothing Accessories
Posted by Catrissa Brown on
Gopro hero3+ scratched broken lens
hi,
here you have it:
http://provideocoalition.com/jfoster/story/gopro-replacement-lenses-for-hero3-3
Apr 19, 2014 | GoPro HD Hero 3: Black Edition Camera
Lens are scratched and arm is broken
eyeglass stores sell scratch filler solution.. and could fix the arm too.
Oct 01, 2013 | Clothing Accessories
How can I repair a scratched lens?
Hi There,
Repairing a scratched is the hardest lens repair to accomplish successfully. It may be worth a shot to check with the manufacturer if ther is some kind of warranty or replacement program. The best option is to replace it. However the cost of replacing the lens may cost more than what the camera is worth. With that in mind, here are a few DIY options things you can try that may or may not work.
1. Scratch Repair Kit
Stuff Needed: Digital camera lens cleaning solution, microfiber cloth and a Scratch Repair kit.
Many companies sell scratch repair kits so there are several available on the market. Do your research to ensure it can work on, and is safe for your lens. Test it on an old camera if you have one lying around just to make the results are what you're looking for.
a. Clean the lens with the lens cleaning solution, and dry it off completely.
b. Follow the instructions provided with the kit.
2. Rubbing Alcohol
Stuff Needed: Digital camera lens cleaning solution, 3 microfiber cloths and a 3.5% solution of rubbing alcohol.
b. Dilute the rubbing alcohol by mixing 20 parts water to 1 part rubbing alcohol to get it to a 3.5% solution.
c. Take a brand new microfiber cloth, dip it in the diluted rubbing alcohol solution, and rub into the scratch using a very gentle motion.
d. You will know if this is working if you start seeing the scratch disappear.
e. Once the scratch has completely disappeared, take another brand new microfiber cloth and dry and buff the entire digital camera lens.
3. Vaseline Method
Stuff Needed: Digital camera lens cleaning solution, 2 microfiber cloths and Vaseline.
b. Dab some Vaseline on your finger and fill the entire scratch with it.
c. Using a new microfiber cloth wipe the Vaseline off very gently. Pressing too hard may cause the Vaseline to sink inside of the scratch.
e. As the Vaseline eventually rubs off, you may need to reapply some more and continue until the scratch disappears completely.
4.Pencil Eraser Method
Stuff Needed: Digital camera lens cleaning solution, 2 microfiber cloths and a new, soft pencil eraser.
a. Clean the lens with the lens cleaning solution,and dry it off completely.
b. Lighlty slide and rub the eraser unp and down along the length of teh scratch.
c. You will know if this is working if you start seeing the scratch disappear.
e. Continue rubbing the eraser until the scratch disappears completely.
NOTE: Never apply the lens cleaning solution directly to the lens itself. Alway dab a microfibre cloth with the solution then clean the lens and allow to dry.
Hope one of these works for you.
Aug 27, 2012 | Olympus SP600UZ Digital Camera
I HAVE A SCRATCH ON MY LENS, 35MM PLEASE HELP I WOULD LIKE TO BUY A REPAIR KIT.
There isn't one. Polishing out a scratch would alter the shape of the lens and ruin the image quality. Anything which fills the scratch will also alter the optical properties.
Just live with it, even fairly bad scratches are rarely visible in the images taken with a scratched lens although they sometimes catch the light at certain angles. using a lens hood will prevent that.
May 29, 2011 | Canon EF 17-35MM F/2.8L USM Lens
So my xbox 360 doesnt want to read the games what should i do?
there are 3 possibilities here. First being that your game discs may be badly scratched or damaged and thus prevents the console from reading the data on the disc. This is so because the lens of the console is very sensitive to scratches and glitches on discs that are inserted. If this is the problem, you have to clean the surface of the disc with a soft lintless cloth and that should do it. Secondly, it could be a fault from your lens. Your lens might be dirty or might be broken. You should try to get a lens cleaner kit and run it in your console to see if this helps the situation but if it doesnt, that could mean a broken lens that needs replacement. Lastly, the console is usually specific to the type of discs it plays. For example. A disc that is marked for an asian region is most likely not to work on a console that was designed for a european region and if that is the case, you have to go through your console's manual for more info on how to solve this. Hope this helped you? Please rate
Dec 08, 2010 | Microsoft Xbox 360 Console
Should I purchase a sunglasses with a glass lens?
Well, here are some facts about glass lenses that might help you reach a better decision.Glass is the only lens material that can be made into 100% optically correct sunglasses. For true vision, there is no comparison between glass and other lens materials.
Glass does not flex or compress. Whenever lenses are placed into an eyewear frame, they are held in place by pressure of some kind. Plastic lenses flex and that creates distortion; but that cannot happen with glass lenses.
Glass does not expand or contract in heat and cold in a significant way. No matter what the temperature outside, 100% optically correct sunglasses will remain 100% optically correct.
Glass is the hardest material, and the most scratch-resistant. Glass is the most durable, and longest-lasting sunglass lens material. However, it is not scratch proof. Sand can scratch glass, but it requires serious effort or trauma to scratch glass lenses.
Technology has made it possible to create a very lightweight glass lens. Today, it can be difficult to tell the difference between glass and plastic, even when holding a pair with glass lenses in one hand and a pair with plastic in the other hand. (Of course, the difference is clear when looking through the lenses. But the weight of the lens is no longer a dead giveaway as to which is which.)
The danger of shattering was once one of the major disadvantages of glass lenses. However, all glass lenses pass the "Drop Ball Test" for impact resistance - the same test that is administered to polycarbonate and CR-39 lenses. When today's polarized lenses tend to break in a similar pattern as a car windshield. The broken pieces of glass mostly stick to the polarizing film that is inside the lens.
These Spotters had been stepped on by the customer. Notice that the broken lens has retained its original curvature. The broken lens pieces were still so tightly held by the frame that we had to smash the broken lens out of the frame with a hammer (it took more than a few smacks, too!). This isn't to say in any way that glass lenses are equivalent to safety glasses. However, polarized glass lenses are much, much less likely to cause injuries today than they ever have been in the past.
Nov 07, 2010 | Clothing Accessories
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
My Wii keeps saying "unable to read game disk". It is a new game with now scratches.
the lens may be bad or needs to be cleaned.is the machine scratching the disk.if so there maybe some kind of foreign object or a broken piece of plastic inside the machine.
Jan 24, 2010 | Nintendo Wii Console
Cd dvd driver compaq v2000 won't burn or play
try cleaning the lens u can carefuly try cleaning it using a small piece of cotton or soft cloth  the lens could be reached when u open the tray of the drive do that with great care the lens is so delicate its could be easily broken or scratched
Oct 17, 2008 | Computers & Internet
Game problem!
This problem occurs when there is some problem with the laser lens, not bad/broken laser. it can be happen if the lens is unclean, e.g. dusty, hampered a piece of plastic and even hair, so the loading game is too slow, and become froze. Cleaning the laser lens, Using a Q tip with a small amount of isopropyl alcohol, gently rub the laser lens, and then use the dry end to remove excess alcohol. don't forget the guide arms that may need re-greasing, as these parts can affect the operation of the console if they are dry.
Hope this be of some help/idea. Pls post back should you need additional information...
Nov 03, 2007 | Sony PlayStation 2 (PS2) Console
Clothing Accessories Logo
42 people viewed this question
Top Roberto Cavalli Clothing Accessories Experts
JonSnell Electronic
JonSnell Electronic
legerdress
legerdress
Bandage Dress
Bandage Dress
Are you a Roberto Cavalli Clothing Accessory Expert? Answer questions, earn points and help others
