Question about Levine Gifts Replacement Bowl with Chain for Hanging Tart Burners - Ivory
Need replacement dish with 3 chains for hanging tart warmer. Where can i find or get one ?
William Schroeder
Posted on Jun 09, 2020
How do I order a replacement hanging dish for tart wax burner?
I would suggest getting in touch with Yankee Candle and asking if they have a replacement for it. It's possible they have some from any main pieces that may have broken and the dish is still okay. But maybe they have replacements in general in case things like breakage happen to the dishes. They've always been very friendly and accommodating when I've had issues or questions and had to call. Good luck!
Chain sprocket hangs, can turn it past the hang by hand but after 3/4 turns it hits the snag again
Hi Drew:
Let's see if I can talk myself through this.
If you dropped the saw off with that problem described here's what I would do:
1) Remove chain and bar.
2) Put bar in vise and hang chain on it, then slide the chain through the slot to make sure that none of the "slides" on the chain were bent. If I found any I would repair or replace them.
3) If roller tip' I would spin it around, make sure it was clean, and lubricate.(There is a "pin hole" grease point that you use a baby grease gun to inject grease)
4) Turn drive sprocket. If it has a "catch point" odds are that one of the clutches or springs has a problem. Temove and service or replace as required.
Hope this helps.
Cheers.
Jan 14, 2016 • Garden
1helpful
HOW DO I GET PIC FROM WEBSITE WITHOUT BORDER SO EBAY ACCEPTS THEM
mouse over pic, right click, rename pic and send it to pic's on your cpu. When asked for pic on the bay go to pictures in cpu and add it
How to put together
Do you have manual? If not email the company for a replacement or download.
Someone recommended this, but I don't understand why do I need the plate warmer?
You don't have to have it, but it adds something to the hosting environment. It helps keep food warm longer on the plate, and it's especially helpful for things like pasta that tend to get cold quickly.
What kinds of dish warmers are there to keep food hot while on display
there are many kinds of dish warmers available to buy or hire:
most company's use tea light heaters or water heaters.
Tea light heaters work by having a number of tea lights under the food to keep it hot. there are also electric warmers available but they require a power source.
40helpful
3answers
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
What kind of oil uses on remington 14" electric chain saw?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank you for using FixYa.
Levine Gifts Replacement Bowl with Chain for Hanging Tart Burners - Ivory Logo
Top Levine Gifts Garden Experts
Jay Finke
Jay Finke
john h
wadingriver
wadingriver
Are you a Levine Gifts Garden Expert? Answer questions, earn points and help others
