Unplug the battery and plug in the AC power plug into the laptop;
Does the laptop start up and stay on?
If yes,
Then put the battery in WHILE IT IS ON; See if it starts charging.
If it does not; You have a bad battery and need to replace it.
If it does start charging here's what happend;
Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all.
The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in.
By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up.
If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue.
Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
